IP statistics, cocnerning high number of IP packets labelled as "with options"
I would like to understand the reason behind getting so many packages labeled as " with options"  and " alerts" in my switch. As you can see in the IP traffic below:
SWITCH_AREA_2#show ip traffic
IP statistics:
  Rcvd:  36935319 total, 1001577 local destination
         0 format errors, 0 checksum errors, 0 bad hop count
         0 unknown protocol, 35933742 not a gateway
         0 security failures, 0 bad options, 439567 with options
  Opts:  0 end, 0 nop, 0 basic security, 0 loose source route
         0 timestamp, 0 extended security, 0 record route
         0 stream ID, 0 strict source route, 439567 alert, 0 cipso, 0 ump
         0 other
  Frags: 0 reassembled, 0 timeouts, 0 couldn't reassemble
         0 fragmented, 0 couldn't fragment
  Bcast: 683780 received, 63 sent
  Mcast: 162045 received, 28563 sent
  Sent:  236736 generated, 0 forwarded
  Drop:  16 encapsulation failed, 0 unresolved, 0 no adjacency
         0 no route, 0 unicast RPF, 0 forced drop
         0 options denied, 0 source IP address zero
ICMP statistics:
  Rcvd: 0 format errors, 0 checksum errors, 0 redirects, 16 unreachable
        14862 echo, 206 echo reply, 0 mask requests, 0 mask replies, 0 quench
        0 parameter, 0 timestamp, 0 info request, 0 other
        0 irdp solicitations, 0 irdp advertisements
  Sent: 0 redirects, 12 unreachable, 355 echo, 14862 echo reply
        0 mask requests, 0 mask replies, 0 quench, 0 timestamp
        0 info reply, 0 time exceeded, 0 parameter problem
TCP statistics:
  Rcvd: 140650 total, 0 checksum errors, 1264 no port
  Sent: 192847 total
UDP statistics:
  Rcvd: 683792 total, 0 checksum errors, 399301 no port
  Sent: 141 total, 0 forwarded broadcasts
BGP statistics:
  Rcvd: 0 total, 0 opens, 0 notifications, 0 updates
        0 keepalives, 0 route-refresh, 0 unrecognized
  Sent: 0 total, 0 opens, 0 notifications, 0 updates
EIGRP-IPv4 statistics:
  Rcvd: 0 total
  Sent: 0 total
PIMv2 statistics: Sent/Received
  Total: 0/0, 0 checksum errors, 0 format errors
  Registers: 0/0 (0 non-rp, 0 non-sm-group), Register Stops: 0/0,  Hellos: 0/0
  Join/Prunes: 0/0, Asserts: 0/0, grafts: 0/0
  Bootstraps: 0/0, Candidate_RP_Advertisements: 0/0
  State-Refresh: 0/0
IGMP statistics: Sent/Received
  Total: 28536/162045, Format errors: 0/0, Checksum errors: 0/0
  Host Queries: 7067/0, Host Reports: 7055/162042, Host Leaves: 0/3
  DVMRP: 0/0, PIM: 14414/0
OSPF statistics:
  Rcvd: 0 total, 0 checksum errors
        0 hello, 0 database desc, 0 link state req
        0 link state updates, 0 link state acks
  Sent: 0 total
ARP statistics:
  Rcvd: 6451839 requests, 244 replies, 0 reverse, 0 other
  Sent: 220 requests, 6078 replies (0 proxy), 0 reverse
  Drop due to input queue full: 0
The switch has a multicast camera attached to it, being it the one which is generating almost all the traffic on the network. How can I make that label go away?
Thanks in advance,
regards!
Everyone's tags (4)
1 REPLY
Silver
Hello Juan,
here you have a similar case, it seems a common hehavior in videoconferencing:
https://supportforums.cisco.com/thread/225491
Best Regards,
Jose.
442
