Community Member
Ip telephony Catalyst Switches
I want to know the Cisco Switches that support Ip Telephony,and can a 2950 tx switch support Ip Telephony for 50 users ?
Silver
Re: Ip telephony Catalyst Switches
All recent cisco switches support the two main features needed for IPT: voice vlan and (Auto-)QoS. They also have PoE models to power the telephone sets. I think that the 2950T has reached EOS. The 3560 is my favorite.
Mohamed, Yes 2950 will support ip telephony. This switch will not provide POE to the IP phones so you have to use either power adaptors for the ip phones or power injectors.You can have CE500,3560,3750 fixed config switches with the POE capabilities for IP telephony.
-amit singh
Community Member
Well..thank You so much Amit...
140
