IP-TV on 3750. Can't configure MVR
Hello!
I am trying to configure multicast streaming. I configured successfully streaming, where server and client are in one VLAN, all is ok, but now I'm trying to stream to different VLANS. I have catalyst 3750 switch and two hosts, one streams, second listens. I configured 3750 like in manual, but can't understand why i don't see the image on client, because mvr members are active.
Network scheme: (client-VLAN10)---/gi1/0/2/---(3750)---/gi1/0/4/---(server-VLAN20)
My switch current config is above:
Current configuration : 3714 bytes
version 12.2
no service pad
hostname cisco3
boot-start-marker
boot-end-marker
enable secret ***
enable password ***
no aaa new-model
switch 1 provision ws-c3750g-24t
system mtu routing 1500
vtp mode transparent
ip subnet-zero
ip routing
ip igmp snooping querier
ip igmp profile 1
    permit
    range 227.24.1.250 227.24.1.250
mvr vlan 20
mvr group 227.24.1.250
mvr
crypto pki trustpoint TP-self-signed-1552593280
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1552593280
revocation-check none
rsakeypair TP-self-signed-1552593280
spanning-tree mode pvst
vlan internal allocation policy ascending
vlan 10
name IPTV-CLIENTS
vlan 20
name IPTV-Server
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
switchport access vlan 10
switchport mode access
mvr type receiver
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
switchport access vlan 20
mvr type source
//nothing configured on interfaces 5 - 24
interface GigabitEthernet1/0/24
interface Vlan1
ip address 83.241.1.1 255.255.255.0
interface Vlan10
description IPTV-clients
ip address 83.241.10.1 255.255.255.0
ip pim dense-mode
interface Vlan20
description IPTV-Server
ip address 83.241.20.1 255.255.255.0
ip pim dense-mode
ip classless
ip http server
ip http secure-server
#show mvr
MVR Running: TRUE
MVR multicast VLAN: 20
MVR Max Multicast Groups: 256
MVR Current multicast groups: 1
MVR Global query response time: 5 (tenths of sec)
MVR Mode: compatible
#show mvr interface
Port      Type       Status           Immediate Leave
Gi1/0/2   RECEIVER   ACTIVE/UP        DISABLED
Gi1/0/4   SOURCE     ACTIVE/UP        DISABLED
#show mvr members
MVR Group IP    Status          Members
227.024.001.250 ACTIVE          Gi1/0/2(d), Gi1/0/4(s)
Any suggestions? Thanks a lot for your answers!
Everyone's tags (5)
Re: IP-TV on 3750. Can't configure MVR
           Just I found in the following Cisco document and already one post in Cisco support community like Multicasting across Vlans. May be you will get some idea.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_25_see/configuration/guide/swigmp.html
https://supportforums.cisco.com/message/3113275
MB.Ahamed
Thank you, but I have read it many times and not only this chapter in this manual, but there wasn't working solutions for me.
1558
