iprouting issue
jfeo
I am not sure if this is a bug
but everytime I enable
ip routing the switch Locks up on me
and I have to reboot it to get it back up.
Here is the model type and
IOS I tried it on both
with same results
WS-C3560-24TS-S
Version 12.2(37)SE1
3560-ipbasek9-mz.122-37.SE1
c3560-ipservicesk9-mz.122-37.SE1
In your current configuration, did you use "ip default-gateway x.x.x.x" to configure the default gateway? If yes, after you enable "ip routing", the switch won't know it's default gateway any more. That's why you could not access the switch.
If possible, try to add "ip route 0.0.0.0 0.0.0.0 " first before you enable "ip routing".
If not possible, you have to telnet/SSH to the switch from its default gateway so that you can still have access to the switch after you enable "ip routing".
HTH.
7 Replies 7
Yudong Wu
Level 7
Level 7
If you enable "ip routing", make sure to use "ip route 0.0.0.0 0.0.0.0 x.x.x.x" to configure your default gateway instead of using "ip default-gateway" command.
I can't
when I issue the command
IP ROUTING
The switch locks up
Well, if you don't have console to the box, you can telnet to this switch from its default gateway.
Here is my problem
The switch is already configured
I am ssh into it from a remote site
I want to enable routing the switch
As soon as I issue the command
IP ROUTING
The switch locks up and I have to get someone to reboot it.
HTH.
ok I Understand now
Thank you for your help
HTH.
