Community Member
IPServices Evaluation License
Hi everyone,
I want to turn on EIGRP functionality on my layer 3 3750 stack. I noticed I was only running an IPBASE license. When I do show license all I notice I have an evaluation of IPSERVICES image (see output below). Can I use this evaluation license? Would it be same as the full license or would it have limited functionality? Also, how do I make it the active license? Please advise.
Q9-Switch#sh license all
License Store: Primary License Storage
StoreIndex: 0   Feature: ipbase                            Version: 1.0
        License Type: Permanent
        License State: Active, In Use
        License Priority: Medium
        License Count: Non-Counted
License Store: Evaluation License Storage
StoreIndex: 0   Feature: ipservices                        Version: 1.0
        License Type: Evaluation
        License State: Active, Not in Use, EULA not accepted
            Evaluation total period: 8  weeks 4  days
            Evaluation period left: 8  weeks 4  days
        License Priority: None
1 ACCEPTED SOLUTION
Hello Ricky,
You require a reboot to complete the activation. Do the below to start the ipservices evaluation
conf t
license level boot ipservices
save it & reboot the device.
Hope it helps.
Vivek
*Please rate helpful posts.
Hello Ricky,
You can enjoy the complete functionality with evaluation license, but it would expire in 8 weeks & 4 days for you. After that, it would revert back to the base license & you would loose specific configs done.
Vivek
Community Member
Thanks Vivek.
How can I make it the active license? Also will it require me to reload?
Hello Ricky,
conf t
Hope it helps.
Vivek
Community Member
Thank you!
1484
