Switching
Get 20% off switches when you combine Cisco solutions
Labels
Hi anyone can assist me on the VPC configuration ? The status not up. VPC Status : switch(config)# show vpcLegend:(*) - local vPC is down, forwarding via vPC peer-link vPC domain id : 700Peer status : peer link is downvPC keep-alive status : Suspende...
Muhd by Level 1
  • 116 Views
  • 4 replies
Hi guys, One of my friend is facing a issue and it seems quite weird.2 of his 9200 switches lost their configuration even though configuration was saved and even if for some reason switch restarted but they should not  loose its configuration. what c...
Hi Team, Two switches are connected to each and that link is a trunk port between those two switches, The challenge is on one switch when I perform cdp/lldp neigbor detail I can see the other switch which is connected to it but funny thing when I pin...
Is it necessary to change the MTU for SVL links in a scenario in which interfaces are configured with MTU larger than default 1500 bytes?Traffic could flow between chassis through SVL links in a Stackwise Virtual cluster. Could not find any reference...
ckuwajima by Level 1
  • 103 Views
  • 3 replies
Resolved! mac flapping
Apr 16 04:14:35.390: %SW_MATM-4-MACFLAP_NOTIF: Host 001b.0907.fe0e in vlan 11 is flapping between port Gi1/1/1 and port Gi1/1/2Apr 16 04:14:35.390: %SW_MATM-4-MACFLAP_NOTIF: Host 001b.0907.fe0e in vlan 11 is flapping between port Gi1/1/1 and port Gi1...
Resolved! PBR VS CONNECTED
hello. I understand that Connected routing has an AD value of 0. The IP bands on the 1st and 2nd floors are different. 1st floor: 1.1.1.0/242nd floor: 2.2.2.0/24 There are two firewalls on top of the backbone. The band will be 3.3.3.0/24. If you conf...
김선명 by Level 1
  • 243 Views
  • 8 replies
