Webcast-Catalyst9k
ipv6 addressing on pc's
When adding an ipv6 address onto a pc, how many addresses do they have, is it 2 ? link local, then either unique local, or global address ? or
hope someone can help
thanks
Carl
1 REPLY
Re: ipv6 addressing on pc's
I think that depends on your OS.
As far as I can tell you always have only the link local address by default (at least on Solaris 10, Linux 2.6 & Windows XP). You will then get a unique local or global address if any other host is responding to either NDP or DHCPv6. Of cause you can add static addresses too if you like.
-Florian
154
