12-20-2008 07:09 PM - edited 03-06-2019 03:04 AM
How can I enable IPv6 addresses and routing on this network module?
Solved! Go to Solution.
12-21-2008 08:44 AM
Richard,
You need to select the dual ipv4/ipv6 SDM template for the ipv6 commands to be available on the module as mentioned in the following configuration guide.
12-21-2008 05:08 AM
Hello Richard,
you need to create a layer2 vlan
vlan 5
name for-ipv6
to associate ports on module with it
ipv6 routing
and to create an SVI
interface Vlan 5
! here you place L3 commands
! including IPv6 commands
Hope to help
Giuseppe
12-21-2008 06:26 AM
the IPv6 commands aren't there
12-21-2008 07:06 AM
Richard,
As Giuseppe indicated, the module just provide the port density to your device. The IPv6 service is provided by whatever IOS feature code you are running in the router.
To identify what IOS feature supports IPv6 for your hardware, please refer to the Cisco Feature Navigator at: http://www.cisco.com/web/go/fn
HTH,
__
Edison.
Please rate helpful posts
12-21-2008 07:29 AM
I have IPv6 running on my router fine but I'm trying to transition to the NME-16ES-1G for lan connectivity
and as its an ES not ESW it runs an IOS of its own independent of the router's IOS
(they of course have to be compatable)
router 3745 w/ IOS c3745-adventerprisek9-mz.124-15.T7
NME-16ES-1G w/ IOS c3750-advipservic
esk9-mz.122-46.SE
since as the cisco doc regarding the NME-16ES-1G says it uses the same line of IOS as the 3750 Switches
if I had a NM-16ESW-1G instead then Giuseppe would be right and it would add ports to the router itself but as its NME-16ES-1G this is not the case
12-21-2008 08:44 AM
Richard,
12-21-2008 09:27 AM
Richard,
I apologize. I made the assumption you were running one of those etherswitch modules without checking the documentation on the aforementioned module.
As Harold indicated, you will run the services as a regular 3750 switch and to have IPv6 features you need to modify the SDM template.
__
Edison.
