IPv6 PIM RP for one group only
I need to configure my router to be RP for 1 group only. It should reject PIM messages for all other groups. I've tried to to the following:
ipv6 pim rp-address XXXX:XXXX:XXXX:XXXX:XXXX:XXXX:XXXX:XXXX ALLOWED_GROUP
ipv6 access-list ALLOWED_GROUP
permit ipv6 any host FF08:YYYY:YYYY:YYYY:YYYY:YYYY:YYYY:YYYY
where XXXX:XXXX:XXXX:XXXX:XXXX:XXXX:XXXX:XXXX - is one of my router's IPv6 addresses that I wish to be RP,
FF08:YYYY:YYYY:YYYY:YYYY:YYYY:YYYY:YYYY - is IPv6 group that I need to allow.
But when I enter the command 'FF08:YYYY:YYYY:YYYY:YYYY:YYYY:YYYY:YYYY', I see the following message: "%Error: Group prefix must be less than 128, skipping FF08:YYYY:YYYY:YYYY:YYYY:YYYY:YYYY:YYYY/128".
Could you please suggest me how can I allow one group only?
Everyone's tags (3)
Use acl as shown below instead of host
permit ipv6 any FF08:YYYY:YYYY:YYYY:YYYY:YYYY:YYYY:YYYY/127
Solomon
Hi Solomon,
But this is interesting - it's been discussed here already and no reasonable answer was given as of yet. What is the reason that you are not allowed to configure an IPv6 PIM-SM RP for a single group? Is this a technical issue of some sort? It just doesn't make sense.
Best regards,
Peter
Hi Peter,
Unfortunately an access-list cannot specify a permit entry for a *single* v6 multicast group. This is a general IOS limitation for now.
Solomon
Hello Solomon,
Thank you for answering!
Exactly, and I am interested in knowing if this limitation is caused by any reasonable technical cause, or whether it is just some (obviously unfortunate) design choice that could be remedied by a relatively simple correction in IOS's source code.
Best regards,
Peter
931
