IPv6 Routing Assistance
greg.bessette
I am trying to setup a test IPv6 network. Currently I have built a VMware infrastructure that can handle both IPv4 and IPv6 traffic. I have connected a physical port from the ESX server to begin connecting real world devices. I am trying to implement IPv6 routing on a Cisco 1812 series router. The IOS version is C181X-ADVIPSERVICESK9-M), version 12.4(6)T8. So far I am able to route IPv4 packets across this mixed network of IPv4 and IPv6. I have followed a multitude of directions to get IPv6 working to no avail. Attached is the network topology and the current running configuration from the router.
The router would be placed in between the virtual and physical networks.
Is there someone who could peruse the documents and let me know where I am going wrong?
Thanks for any assistance
Greg
Please move if I placed in the wrong forum section.
21 Replies 21
Giuseppe Larosa
Hello Greg,
usually on lan interface eui-64 formats are used:
Example:
ipv6 unicast-routing
interface ethernet 0
ipv6 address 2001:0DB8:c18:1::/64 eui-64
I have some doubts on you FE0 config:
interface FastEthernet0
ip address 10.0.3.2 255.255.255.0
duplex auto
speed auto
>>>ipv6 address autoconfig
ipv6 rip process1 enable
I would change it with the appropriare eui-64 address.
There is someone that can give an IPv6 address to the router ?
To enable automatic configuration of IPv6 addresses using stateless autoconfiguration on an interface and enable IPv6 processing on the interface, use the ipv6 address autoconfig command in interface configuration mode. Addresses are configured depending on the prefixes received in Router Advertisement messages. To remove the address from the interface, use the no form of this command.
see
http://www.cisco.com/en/US/docs/ios/ipv6/command/reference/ipv6_05.html#wp2114586
http://www.cisco.com/en/US/docs/ios/ipv6/configuration/guide/ip6-addrg_bsc_con.html#wp1282543
Hope to help
Giuseppe
burleyman
Level 8
Level 8
I noticed your running RIPv2. I don believe it works with RIP 1 or 2....I think you need what is called RIPng (New Generation). I will see if I can find where that is stated.
Mike
greg.bessette
Thanks so far.....I am going to make the modifications specified and will let you know.
Greg
greg.bessette
I am placing my updated router config. I am still not able to RIP over IPv6. If I run a packet capture on FA1, I can see RIPng responses from the router interface. On FA0, I see nothing from the packet capture.
Thanks for any continued assistance.
Hello Greg,
I see you are using EUI-64 ip addresses now.
I think the following static routes are not needed:
ipv6 route 2001:DB:0:3::/64 FastEthernet0
ipv6 route 2001:DB:0:4::/64 FastEthernet1
these are exactly the ipv6 subnets out those interfaces.
the same applies for ipv4 :
ip route 10.0.3.0 255.255.255.0 FastEthernet0
ip route 10.0.4.0 255.255.255.0 FastEthernet1
Do you see RIP (for ipv4 frames ) on both interfaces ?
Hope to help
Giuseppe
I currently see rip for ipv4 frames on both sides. I can route with no problem using IPv4 after I pulled the static routes as you suggested. IPv6 still does not work.
Greg
Here is some additional information. I run the sh ipv6 rip 6route database and I get the following:
IPv6_Router1#sh ipv6 rip 6route database
RIP process "6route", local RIB
For sh ipv6 route, I get the following:
IPv6_Router1#sh ipv6 route
IPv6 Routing Table - 6 entries
Codes: C - Connected, L - Local, S - Static, R - RIP, B - BGP
U - Per-user Static route
I1 - ISIS L1, I2 - ISIS L2, IA - ISIS interarea, IS - ISIS summary
O - OSPF intra, OI - OSPF inter, OE1 - OSPF ext 1, OE2 - OSPF ext 2
ON1 - OSPF NSSA ext 1, ON2 - OSPF NSSA ext 2
D - EIGRP, EX - EIGRP external
C 2001:DB8:0:3::/64 [0/0]
via ::, FastEthernet0
L 2001:DB8:0:3:21D:45FF:FE89:D376/128 [0/0]
C 2001:DB8:0:4::/64 [0/0]
via ::, FastEthernet1
L 2001:DB8:0:4:21D:45FF:FE89:D377/128 [0/0]
L FE80::/10 [0/0]
via ::, Null0
L FF00::/8 [0/0]
via ::, Null0
Let me know if there is any other information that you may need.
Greg
Greg,
Even if you don't receive any routes from your neighbor, you should at least see the local routes in the rip database. Can you provide a "show ipv6 proto", "show ipv6 int fa0" and "show ipv6 int fa1".
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Here are the results:
IPv6_Router1#sh ipv6 proto
IPv6 Routing Protocol is "connected"
IPv6 Routing Protocol is "static"
IPv6 Routing Protocol is "rip 6route"
Interfaces:
FastEthernet1
FastEthernet0
Redistribution:
None
IPv6_Router1#sh ipv6 int fa0
FastEthernet0 is up, line protocol is up
IPv6 is enabled, link-local address is FE80::21D:45FF:FE89:D376
No Virtual link-local address(es):
Global unicast address(es):
2001:DB8:0:3:21D:45FF:FE89:D376, subnet is 2001:DB8:0:3::/64 [EUI]
Joined group address(es):
FF02::1
FF02::2
FF02::9
FF02::1:FF89:D376
MTU is 1500 bytes
ICMP error messages limited to one every 100 milliseconds
ICMP redirects are enabled
ICMP unreachables are sent
ND DAD is enabled, number of DAD attempts: 1
ND reachable time is 30000 milliseconds
ND advertised reachable time is 0 milliseconds
ND advertised retransmit interval is 0 milliseconds
ND router advertisements are sent every 200 seconds
ND router advertisements live for 1800 seconds
ND advertised default router preference is Medium
Hosts use stateless autoconfig for addresses.
IPv6_Router1#sh ipv6 int fa1
FastEthernet1 is up, line protocol is up
IPv6 is enabled, link-local address is FE80::21D:45FF:FE89:D377
2001:DB8:0:4:21D:45FF:FE89:D377, subnet is 2001:DB8:0:4::/64 [EUI]
FF02::1
FF02::2
FF02::9
FF02::1:FF89:D377
MTU is 1500 bytes
Greg,
Everything looks good except that the RIP database is empty. I would try to upgrade to a more recent image in the 12.4T train.
regards
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Here is the latest. I have upgraded to the latest IOS and still have an empty RIP database.
This is the latest config:
Current configuration : 1371 bytes
version 12.4
hostname Router
boot-start-marker
boot system flash:c181x-advipservicesk9-mz.124-22.T.bin
boot-end-marker
logging message-counter syslog
no aaa new-model
dot11 syslog
ip source-route
ip cef
ipv6 cef
archive
log config
hidekeys
duplex auto
speed auto
ipv6 address 2001:DB8:0:3::/64 eui-64
ipv6 enable
ipv6 rip 6route enable
interface FastEthernet1
ip address 10.0.4.1 255.255.255.0
duplex auto
speed auto
ipv6 address 2001:DB8:0:4::/64 eui-64
ipv6 enable
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface FastEthernet9
interface Vlan1
no ip address
router rip
network 10.0.0.0
ip forward-protocol nd
no ip http server
no ip http secure-server
ipv6 router rip 6route
control-plane
line con 0
line aux 0
line vty 0 4
login
webvpn context Default_context
ssl authenticate verify all
no inservice
end
I am going to fire up the second router that I have and see if there may be a hardware issue with this router. I am at a complete loss.
Hopefully I missed something in the config.
Thanks again
Greg
I am now starting to receive this error message. I am try to locate what this error means.
*Dec 1 16:37:19.163: %IPV6_ND-3-CONFLICT: Router FE80::250:56FF:FEAD:1B3E on Fa
stEthernet0 conflicting ND setting prefix 2001:DB8:0:3::/64 valid lifetime, diff
erence 4292375295 seconds
Greg,
This message should not prevent the router from receiving the RIP routes. Can you do a "show ipv6 rip" and run a "debug ipv6 rip".
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
