IPv6
Hello!
i have seen this Config for IPv6:
frame-relay map ipv6 2001:CC5E:4321:ABCD::10/64 110
frame-relay map ipv6 FE80::CCE3:1FFF:FEB7:0 110
THE QUESTION:What is this:FE80::CCE3:1FFF:FEB7:0?how can i find it?
10xs
Hall of Fame Super Bronze
Re: IPv6
The link-local address (FE80::) is needed there to transport dynamic routing information (OSPFv3 and RIPng) over the frame-relay.
You can find it by typing show ipv6 int brief
Re: IPv6
hello freind
EdisonOrtiz:do i need it in my Config?i mean the map statments?
2)The requirments says R10 Lo0 sould be part of the EIGRP 100.Can r10 have this interface into EIGRP 100 AND OSPF AREA 0?
ON R10 i have redistribution between ospf 1 and eigrp 100
can i redistribut to ospf 1 2 eigrp as
like eigrp 100 and eigrp 150
10xs a lot
10XS
Re: IPv6
I'm sorry - I'm confused.
Your first query was regarding IPv6 and the second query is regarding IPv4 dynamic routing protocols.
I believe the answer is, whatever you have in the frame-relay ipv6 statement, it won't affect your IPv4 routing protocols.
You need IPv4 frame map statements as well.
__________________________________________
As for this question:
"The requirments says R10 Lo0 sould be part of the EIGRP 100.Can r10 have this interface into EIGRP 100 AND OSPF AREA 0?"
You can have an interface participating on 2 dynamic routing protocols but it's not 'best practice' and often discourage. For Lab work, yeah it's cool to play around with it but never should be done in production.
Re: IPv6
man
no need to be confused.10xs a lot...
Re: IPv6
hello
can this work fine:
router ospf 1
redis eigrp 100 metric 1 1 1 1 1
redis eigrp 150 metric 1 1 1 1 1
10xs
Re: IPv6
sorry
i mean these:
router ospf 1
redis eigrp 100 subnets
redis eigrp 150 subnets
10xs
Re: IPv6
Yes, that should work. It's not mandatory to include a metric value when redistributing into OSPF.
Re: IPv6
You are missing the 'subnets' keyword so redistributed routes into OSPF can be classless.
Also, the metric illustrated is for redistribution into EIGRP.
OSPF only uses one metric
142
