Webcast-Catalyst9k
IPX routing across vlans
Two Novell 3.x (DOS) PCs which try to access Windows server running NW Services for Microsoft. Windows server is on VLAN 100 and Novell PCs are on VLAN 50.
W2K Server
IPX "name" NW-S05
192.168.193.152
Switchport set to VLAN 100
DOS PCs
Novell Client
Ethernet II
Switchport set to VLAN 50
L3 Core switch (C6509) is being used for routing between vlans.
Does anyone have a sample config of how vlan interface should be configured to "route ipx" between the vlans?
TIA
1 REPLY
Re: IPX routing across vlans
IPX routing works similar to IP routing.
When your router (C6509) supports IPX you should assign an IPX network to each vlan and then it will work.
Most important question is whether IPX is supported on the core. Please post your version info if you want us to check.
regards,
Leo
283
