IPX tunnel over IP
tunemore1
Need sample config for IPX tunnel over IP (two IPX LAN connected with IP only link).
Harold Ritter
It can be as simple as configuring a GRE tunnel and applying an IPX address on it as follow:
interface Tunnel0
no ip address
ipx network deadbeef
tunnel source xyz
tunnel destination abc
Make sure you include this address under your routing protocol.
Hope this helps,
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Harold Ritter
interface Tunnel0
no ip address
tunnel source xyz
Hope this helps,
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Thanks. Do you know a good link about it on Cisco site?
I found the attached file in PDF format.
Hope this helps,
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Please tell me some example Cisco router that will accept Harold Ritter's solution.  I'd like to use two RV340 routers, in a North American (California) incarnation.     IPX tunnel via IP.      Simple point-to-point job.       Thanks.
