IR829GW - Problems to conf. the cellular interface
julioegb
Hello everyone. My company has just bought a IR829GW, the idea is install this equipment in a vehicle to give WiFi connection.
It's my first time configuring a cellular interface, I want to use a SIM from Claro Guatemala, this ISP doen't need authentication, I had already configured the profile and I think it's ok:
IR800#show cell 0 profile
Profile 1 = INACTIVE **
PDP Type = IPv4
Access Point Name (APN) = Broadband
Authentication = None
Profile 15 = INACTIVE*
PDP Type = IPv4
Access Point Name (APN) = internet.ideasclaro
Profile 16 = INACTIVE
PDP Type = IPv4
* - Default profile
** - LTE attach profile
I configured the int cell 0 with this commands:
interface Cellular0
 ip address negotiated
 encapsulation slip
 dialer in-band
 dialer-group 1
end
And the controller:
controller Cellular 0
lte sim data-profile 15 attach-profile 1 slot 0
lte modem link-recovery rssi onset-threshold -110
lte modem link-recovery monitor-timer 20
lte modem link-recovery wait-timer 10
lte modem link-recovery debounce-count 6
The problem is that I can't obtain an IP addres from the ISP in the interface cellular, please I need help:
IR800#show ip int brief
Interface                  IP-Address      OK? Method Status                Protocol
GigabitEthernet0           unassigned      YES NVRAM  administratively down down
GigabitEthernet1           unassigned      YES unset  down                  down
GigabitEthernet2           unassigned      YES unset  down                  down
GigabitEthernet3           unassigned      YES unset  down                  down
GigabitEthernet4           unassigned      YES unset  down                  down
Wlan-GigabitEthernet0      unassigned      YES unset  up                    up
Async0                     unassigned      YES unset  up                    down
Async1                     unassigned      YES unset  up                    down
GigabitEthernet5           unassigned      YES NVRAM  administratively down down
Cellular0                  unassigned      YES manual up                    up
Cellular1                  unassigned      YES NVRAM  down                  down
Julio Guzmán
2 Accepted Solutions
Ben Walters
Level 3
Level 3
For your controller you used lte sim data-profile 15 attach-profile 1 slot 0 but it should be lte sim data-profile 15 attach-profile 15 slot 0 otherwise in your current setup it will try to use profile 1 to attach to the LTE network not the profile 15 you already created.
You may be missing a couple things in your int Cell 0 configuration.
interface Cellular0
ip virtual-reassembly in
encapsulation slip
dialer in-band
dialer idle-timeout 0
dialer enable-timeout 6
dialer string lte
dialer-group 1
async mode interactive
try and add the lines in bold to your cellular interface configuration:
interface Cellular0
encapsulation slip
dialer in-band
dialer string lte
dialer-group 1
no peer default ip address
routing dynamic
That said, how are you triggering/activating the interface ? You currently have no IP addressing configured locally...
8 Replies 8
Ben Walters
Level 3
Level 3
interface Cellular0
encapsulation slip
dialer in-band
dialer string lte
dialer-group 1
Ben Thanks for your valuable help, you're rigth with the profile and with the other commands, I had change the wrong command and included the new ones but nothing change, my int cellular 0 doesn't have IP address, the complete conf. of the IR829 is:
Mobile_Router#show runn
Building configuration...
Current configuration : 2871 bytes
! Last configuration change at 19:29:17 UTC Fri Dec 29 2017
version 15.6
hostname Mobile_Router
boot-start-marker
boot system flash:ir800-universalk9-mz.SPA.156-3.M
boot-end-marker
no aaa new-model
ethernet lmi ce
service-module wlan-ap 0 bootimage autonomous
ignition off-timer 900
ignition undervoltage threshold 9
no ignition enable
ip dhcp excluded-address 192.168.43.1 192.168.43.6
ip dhcp pool W_DHCP
 network 192.168.43.0 255.255.255.0
 default-router 192.168.43.1
 domain-name Allied.network
 dns-server 8.8.8.8
ip cef
no ipv6 cef
chat-script lte "" "AT!CALL" TIMEOUT 20 "OK"
license udi pid IR829GW-LTE-NA-AK9 sn FTX2043Z010
redundancy
interface GigabitEthernet0
 no ip address
 shutdown
interface GigabitEthernet1
 no ip address
interface GigabitEthernet2
 no ip address
interface GigabitEthernet3
 no ip address
interface GigabitEthernet4
 no ip address
interface Wlan-GigabitEthernet0
 no ip address
interface GigabitEthernet5
 no ip address
 shutdown
 duplex auto
 speed auto
interface Cellular0
 encapsulation slip
 dialer in-band
 dialer string lte
 dialer-group 1
interface Cellular1
 no ip address
 encapsulation slip
interface wlan-ap0
 ip address 1.1.1.1 255.255.255.255
interface Vlan1
 no ip address
interface Async0
 no ip address
 encapsulation scada
interface Async1
 no ip address
 encapsulation scada
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 Cellular0
dialer-list 1 protocol ip permit
ipv6 ioam timestamp
access-list 1 permit any
control-plane
line con 0
 stopbits 1
line 1 2
 stopbits 1
line 3
 script dialer lte
 no exec
 transport preferred lat pad telnet rlogin lapb-ta mop udptn v120 ssh
 transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
line 4
 no activation-character
 no exec
 transport preferred none
 transport input all
line 8
 no exec
line 1/3 1/6
 transport output none
 stopbits 1
line vty 0 4
 login
 transport input none
no scheduler max-task-time
end
Look this show command:
Mobile_Router#show cellular 0 network
Current System Time = Fri Dec 29 19:18:28 2017
Current Service Status = No service
Current Service = Unknown
Current Roaming Status = Home
Network Selection Mode = Automatic
Network =
Mobile Country Code (MCC) = 704
Mobile Network Code (MNC) = 1
Packet switch domain(PS) state = Not attached
Location Area Code (LAC) = 0
Cell ID = 0
This is the show for the hardware:
Mobile_Router#show cellular 0 hardware
Modem Firmware Version = SWI9X15C_05.05.58.00
Modem Firmware built = 2015/03/04 21:30:23
Hardware Version = 1.0
Device Model ID: MC7354
Package Identifier ID: 1102037_9903214_MC7354_05.05.58.00_00_Cisco_005.009_000
International Mobile Subscriber Identity (IMSI) =
International Mobile Equipment Identity (IMEI) = 356734060308776
Integrated Circuit Card ID (ICCID) =
Mobile Subscriber Integrated Services
Digital Network-Number (MSISDN) =
Modem Status = Online
Current Modem Temperature = 35 deg C
PRI SKU ID = 9903214, PRI version = 005.026, Carrier = AT&T
This is the profile info:
Mobile_Router#show cell 0 profile
PDP Type = IPv4
Profile 15 = INACTIVE* **
PDP Type = IPv4
PDP Type = IPv4
  * - Default profile
The configuration of my interfaces:
Mobile_Router#show ip int brief
GigabitEthernet1           unassigned      YES unset  up                    up
Again thanks for your help, It's hard to find information about this, I feel like I'm lost in the jungle.
Julio Guzmán
Are you able to post the output from sho cell 0 all?
It may give more information as to why the cellular is not connecting. Are you sure that the APN is correct for your carrier too?
Thanks Ben, below the info of the show cell 0 all:
Mobile_Router#show cell 0 all
Hardware Information
International Mobile Subscriber Identity (IMSI) = 704012024396712
Integrated Circuit Card ID (ICCID) = 8950201016696768069
Current Modem Temperature = 23 deg C
Profile Information
PDP Type = IPv4
PDP Type = IPv4
PDP Type = IPv4
  * - Default profile
Configured default profile for active SIM 0 is profile 15.
Data Connection Information
Profile 1, Packet Session Status = INACTIVE
Profile 2, Packet Session Status = INACTIVE
Profile 3, Packet Session Status = INACTIVE
Profile 4, Packet Session Status = INACTIVE
Profile 5, Packet Session Status = INACTIVE
Profile 6, Packet Session Status = INACTIVE
Profile 7, Packet Session Status = INACTIVE
Profile 8, Packet Session Status = INACTIVE
Profile 9, Packet Session Status = INACTIVE
Profile 10, Packet Session Status = INACTIVE
Profile 11, Packet Session Status = INACTIVE
Profile 12, Packet Session Status = INACTIVE
Profile 13, Packet Session Status = INACTIVE
Profile 14, Packet Session Status = INACTIVE
Profile 15, Packet Session Status = INACTIVE
Profile 16, Packet Session Status = INACTIVE
Network Information
Current System Time = Tue Jan 2 15:8:59 2018
Current Service Status = Normal
Current Service = Packet switched
Network =
Packet switch domain(PS) state = Attached
Location Area Code (LAC) = 499
Cell ID = 13595054
Radio Information
Radio power mode = online
Channel Number = 9716
Current Band = WCDMA 1900
Current RSSI(RSCP) = -49 dBm
Current ECIO = -5 dBm
Primary Scrambling Code = 0x122
Number of nearby cells = 2
Idx      PSC (Primary Scrambling Code)
1              101
2              253
Radio Access Technology(RAT) Preference = AUTO
Radio Access Technology(RAT) Selected = UMTS ( HSDPA HSUPA UMTS/WCDMA )
Modem Security Information
Active SIM = 0
SIM switchover attempts = 0
Card Holder Verification (CHV1) = Disabled
SIM Status = General failure
SIM User Operation Required = None
Number of CHV1 Retries remaining = 0
GPS Information
GPS Info
GPS Feature: enabled
GPS Port Selected: Dedicated GPS port
GPS Status: GPS location cannot be acquired
GPS auto tracking status: unknown
GPS auto tracking config: disabled
GPS Mode Configured: not configured/unknown
Last Location Fix Error: Offline [0x0]
SMS Information
Incoming Message Information
SMS stored in modem = 0
SMS archived since booting up = 0
Total SMS deleted since booting up = 0
Storage records allocated = 25
Storage records used = 0
Number of callbacks triggered by SMS = 0
Number of successful archive since booting up = 0
Number of failed archive since booting up = 0
Outgoing Message Information
Total SMS sent successfully = 0
Total SMS send failure = 0
Number of outgoing SMS pending = 0
Last Outgoing SMS Status = SUCCESS
Copy-to-SIM Status =     0x0
Send-to-Network Status = 0x0
Report-Outgoing-Message-Number:
  Reference Number =     0
  Result Code =          0x0
  Diag Code =            0x0 0x0 0x0 0x0 0x0
SMS Archive URL =
Error Information
This command is not supported on this platform.
Modem Crashdump Information
WIC type is 00
Cellular0 is MC73xx based
Modem crashdump logging: off
interface Cellular0
encapsulation slip
dialer in-band
dialer string lte
dialer-group 1
routing dynamic
I think I see the issue here, you may not have the correct model of 829 for your provider.
If you look here:
https://www.cisco.com/c/en/us/products/collateral/routers/829-industrial-router/datasheet-c78-734981.html
Under Table 2. 4G LTE Specifications, you will see that there are different models of 829 for service providers and regions. It looks like you have the North American AT&T(IR829GW-LTE-NA-AK9) model when you may need a LATAM model. Claro seems to use the 1800 LTE band 3 (Wikipedia) so you may need to use the IR829GW-LTE-GA-*K9 model of 829.
That is the only other thing that I can think of at this time. The rest of the config looks ok to the point where you should at least be connecting to a cell network and have an IP address on the router.
https://en.wikipedia.org/wiki/LTE_frequency_bands - second table had the Claro information.
Thanks for your help Ben, I don't know why but I made your changes and it didn't work. I included the commands that Georg suggest me and it didn't work too.
I looked the bands of the ISP, I found my IR829 support the actual bands of CLARO Guatemala.
Too try another configuration, I started to configure the DHCP server of the device, I had a problem in my DHCP configuration which my int vlan address. I changed the wrong address and after that the cellular interface start to work fine.
I really appreciate your help and assistance Ben and Georg, It's the first time I used this forum, but I going to use it frequently.
Julio Guzmán
Normally with an LT router you need a Dialer Interface to get and IP address
interface Dialer1
encapsulation slip
dialer pool 1
dialer string lte
dialer persistent
My 2 Cents worth!
