iRDP Not on 3560
I bought a new 3560 and the image does not support iRDP. This a protocol I need for a project. Which image do I need to download and how is it done without loosing the current config.
  • LAN Switching and Routing
Super Bronze
Re: iRDP Not on 3560
fyi:
I just scanned the latest command reference manaual for the 3560, didn't find any references to iRDP.
PS:
Altough I have found it documented for routers, it might not be supported on the 3650s (like other 3560/3750 non-supported First Hop Redundancy Protocols).
Yes, its not support. How can I download a new image to support it.
Super Bronze
It might not be supported in any image.
This is the version of the software being run.
Switch Ports Model SW Version SW Image
* 1 26 WS-C3560-24PS 12.2(35)SE5 C3560-IPBASE-M
Is there a way to bypass the iRPD requirement on the Cisco BTS 10200. Thats what I'm using this switch to connect to. Thanks.
276
