Irregularities with Traceroure Nexus 7000
Hi, I have problems running the traceroute command on a Nexus, I explain to them
* I have two devices Nexus7000, each has three context,
when executing a traceroute to pass through the core01,  this showed a delay (*****),  did not display the next hop to the core01
to resolve the problem we disable the "ip icmp redirects" on core interfaces. This solved the problem partially, Now when you run the traceroute it responds without problem if run from another device goes smoothly through core01, if you run the traceroute in the core01 or its contexts, the problem occurs in the next hop (one of the contexts), the first traceroute respond smoothly,  if you run the same traceroute shows a delay  (****),  if you run the same traceroute respond smoothly,  and if I return again to run the trace is shown the delay or not responding ....
I hope you can help me, because I find the possible problem.
Everyone's tags (2)
317
