Community Member
IS 4507R FAN Tray hot swappable?
We have a Cisco 4507R switch with sup V. This switch fan tray has partial problem .No light in fan tray. We got another fan tray. Can any one tells me is it hot swappable?
What procedure should I flow without any interruption our live network?
Would be appreciated if let me know.
Thank
Amin
Everyone's tags (5)
1 ACCEPTED SOLUTION
Re: IS 4507R FAN Tray hot swappable?
Hi Amin,
It is hot-swappable but you have to be very fast with replacement to avoid system overheating. See the Caution note in the guide:
"When changing fan assemblies, try to keep  changeover times to under a minute. Never operate the system for an  extended period if the fan assembly is removed or if it is not  functioning properly. An overtemperature condition can cause severe  equipment damage or an unscheduled system shutdown."
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/hardware/configuration/notes/78_15335.html#wp37421
Hot-swap feature is confirmed by this guide, table 1-3:
"One hot-swappable fan assembly"
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/hardware/installation/guide/78-14409-08/01intro.html#wp1028573
Kind Regards,
Ivan
**Please grade this post if you find it useful.
Kind Regards, Ivan Shirshin **Please grade this post if you find it useful.
VIP Super Bronze
Hi Amin,
According to the installation guide, the 4507R comes with one fan tray and 6 fans.  So, you don't have redundant fan trays.  It sounds as you need an outage window to turn off the switch, replace the old fan tray with the new one and turn the switch back on.
Here is the instalation guide:
FAN TRAYS
Each Cisco Catalyst 4500 Series chassis uses a single fan tray for cooling. All fan trays are composed of independent fans. If one fan fails, the system
will continue to operate without a significant degradation in cooling. The system will detect and notify the user (through LED, command-line
interface [CLI], and SNMP) that a fan has failed and the tray needs to be replaced.
http://www.berkcom.com/resources/cisco/C4500_cdccont_0900aecd801792b1.pdf
Hi Amin,
Kind Regards,
Ivan
Community Member
Hi Reza/Ivan
Thanks for your valuable post. I have done replacement without any trouble.
Amin
Glad everything is good, Amin, and thanks for rating the posts!
2255
