Is BFD supported in SR 3750G
yoram12345
hi all,
Just want to verify the following
I have switch router 3750G with IOS 12.2(25)SEB .
However i could not operate BGD on it.(command does not appear)
I believe BFD is not supported in this IOS ver.
Is it supported in other version maybe ?
I need it for Lab simulation
Thanks Yoram
yoram12345 wrote:
Hi Jhon,
I understand that 3750 METRO is more powerfull in term f features than 3750G that i have.
Can u upgrade the IOS and change mine to 3750 metro or is it other hw.
if its other hw how can i be sure what i have
BR,
Yoram
Yoram
As Varun says, it is different hardware. A "sh version" should show you which switch you have.
Jon
6 Replies 6
Jon Marshall
yoram12345 wrote:
hi all,
Thanks Yoram
Yoram
Unfortunately the 3750 does not support BFD no matter what the IOS. The 3750 Metro series switch does have BFD support.
Jon
hi Jhon,
Thanks for the answer.
Just last question as i am not so familiar with teh different types :
what is teh difference between 3750G and the 3750G metro series.
maybe my device belong to the metro series.
How can i verify that ?
BR,
Yoram
Hi Jhon,
BR,
Yoram
its a diff h/w with the metro link on it that acts as the wan link for you
Varun
yoram12345 wrote:
Hi Jhon,
BR,
Yoram
Yoram
Jon
thanks
