Is bpdu filter enable best practice for access ports with portfast
darrenriley5
Could someone please confirm if applying bpdu filter enable on access ports with portfast enabled is best practice?
Darren
3 Accepted Solutions
BPDU guard will error disable the port if it detect BPDU (another switch).
BPDU filter will turn off portfast if it detect BPDU.
If a BPDU is received on a Port Fast-enabled  interface, the interface loses its Port Fast-operational status, and  BPDU filtering is disabled.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_44_se/configuration/guide/swstpopt.html#wp1095752
HTH,
jerry
Leo Laohoo
Personally, for an access port, I'd go for STP portfast and BPDU Guard enabled.  For trunk ports I have both disabled.
Giuseppe Larosa
Hello Darren,
No it isn't, use bpdu guard + portfast it is more safe.
if you make a search in the forums you will find several issues caused by bpdu filter (possible bridging loops)
Hope to help
Giuseppe
6 Replies 6
Jerry Ye
Depend on your company's policy. If you want the port to be hard down when someone plug a switch into a portfast enabled port, then you should use bpdu guard. If your policy is to allow switch into portfast enabled port, then bpdu filter is a better approach.
HTH,
jerry
I thought you could use both. BPDU guard to protect a port if it receives a BPDU so error disables the port.
Then BPDU filter simply to stop sending BPDU's from the port.
HTH,
jerry
Leo Laohoo
Giuseppe Larosa
Hello Darren,
Hope to help
Giuseppe
Many thanks for everyone's replies. A CCIE engineer recently came and configured two Nexus 7000 switches for us and applied the spanning-tree bpduguard enable and spanning-tree bpdufilter enable on every access port which I found strange. Now I have confirmation I will remove the spanning-tree bpdufilter command from the access ports.
