Is it possible to connect fibre optic cable diretly to router?..
vinothlb1
Is it possible to connect fibre optic cable(provided by ISP) directly to router without v.35 and g.703 modem.. If we need any converter what type of converter needed..
Collin Clark
Some router models have an available SFP port where you could plug in the fiber. As you stated you could also use a media converter. I prefer Transition, here's a link to a sample product.
http://transition.com/TransitionNetworks/Products2/Family.aspx?Name=M%2fGE-PSW-xX-01
Leo Laohoo
Colin's right. The 3800 router has one port that's a "dual personality". All you need is the correct SFP module.
Other routers, such as the 1800 and 2800 support the HWIC-1GE. Again, all you need is the correct SFP module.
Cisco Gigabit Ethernet High-Speed WAN Interface Card
http://www.cisco.com/en/US/prod/collateral/routers/ps5854/product_data_sheet0900aecd8016be8d_ps5949_Products_Data_Sheet.html
Hope this helps.
