Is it possible to use the 4ESW on a Cisco 2611XM ?
I try to use my 4ESW HWIC (and my 1T) module on my Cisco 2611XM (It was on my Cisco 1700 before, and works fine on it), So I remove it from my old router, and plug it into my new router, but when I start the router, it don't detect it (but it detect the 1T module), I get this message at boot :
Cisco 2611XM (MPC860P) processor (revision 1.0) with 94540K/3764K bytes of memory.
Processor board ID JAD0703049W
M860 processor: part number 5, mask 2
2 FastEthernet interfaces
1 Serial interface
32K bytes of NVRAM.
32768K bytes of processor board System flash (Read/Write)
Slot is empty or does not support clock participate
WIC slot is empty or does not support clock participate
SETUP: new interface Serial0/0 placed in "shutdown" state
It detect the serial module, it's own FastEthernet interfaces, but nothing about the 4ESW module... Nothing appear in the "show interfaces" command too,
So I switched the 1T and the 4ESW module to verify if the HWIC port is dead, fortunaly that's not the case, same problem...
It's really strange, it looks like there is something incompatible, because both the Router HWIC port works fine with the 1T module and on ther other side the 4ESW works fine on the Cisco 1700...
Is there anything to setup to make it works ? I never used the HWIC interfaces on something else than my old Cisco 1700...
My firmware is : c2600-advipservicesk9-mz.124-25b.bin
Thank you
Everyone's tags (3)
1 ACCEPTED SOLUTION
VIP Super Bronze
Re: Is it possible to use the 4ESW on a Cisco 2611XM ?
Hi Mathieu,
It does not seem that it is supported for 2600 series.
From the data sheet:
This document provides configuration tasks for the 4-port Cisco HWIC-4ESW and the 9-port Cisco HWIC-D-9ESW EtherSwitch high-speed WAN interface cards (HWICs) hardware feature supported on Cisco 1800 (modular), Cisco 2800, and Cisco 3800 series integrated services routers.
More info:
http://www.cisco.com/en/US/docs/ios/lanswitch/configuration/guide/lsw_hwic_ethsw_ic_ps6441_TSD_Products_Configuration_Guide_Chapter.html
Reza
VIP Super Bronze
Hi Mathieu,
More info:
Reza
Thank you, I think I've found a document that list the modules that could be compatible with the 2611XM :
http://www.cisco.com/en/US/products/hw/routers/ps259/products_relevant_interfaces_and_modules.html
Purple
  No its not supported on a 2611xm. These are the supported platforms.
Chassis
4-Port Cisco EtherSwitch HWIC
9-Port Cisco EtherSwitch HWIC
Internal Inline Power Supply (optional)
Cisco 1841
Yes, 2 HWICs per router
No
No
Cisco 1941
Yes, 1 HWIC per router
Yes
Cisco 1941W
No
No
Yes
Cisco 2801
Yes
Cisco 2901
Yes, 2 HWIC per router
Yes
Cisco 2811
Yes
Cisco 2911
Yes
Cisco 2821
Yes
Cisco 2921
Yes
Cisco 2851
Yes
Cisco 2951
Yes
Cisco 3825
Yes
Cisco 3925
Yes
Cisco 3845
Yes
Cisco 3945
Yes
As answered, the HWIC-4ESW you have is not supported, but note that the earlier WIC-4ESW is supported in the 2600 series.
The 2600 has WIC slots and the 2800 has HWIC slots.  HWIC's are of course backwards compatible with WIC cards.
1272
