Is it safe to use one pre-share key for hub to spokes connection when using dmvpn
Hello Expert,
I have hub and spoke(s) enviroment using mix of 2811 and 2900 series router
I using DMVPN for my tunnels.
I am think about using one pre-share key thru out the  hub and spokes vpn configuration, but  I unsure about the risk.
Would the above be safe or should i use unique key for each hub to spokes connection ?.
1 ACCEPTED SOLUTION
Re: Is it safe to use one pre-share key for hub to spokes conne
Hi there,
The main risk of using the same PSK across all connections is that if one is compromised, then all the others are immediately at risk and can easily be compromised too.
At the end of the day, it is up to you/company policy as to whether you are prepared to take that risk.
Many thanks
Jonathan
1 REPLY
Hi there,
Many thanks
Jonathan
225
