Is routing after NAT possible?
network_user
Is there a way I can make routing decision on a cisco router after the NAT? I want to route traffic to a specific next hop after the NAT has happened.
Is there a way to do this?
Thank you.
Rajeev Sharma
Hey,
Check if this works for you:
http://www.cisco.com/c/en/us/support/docs/ip/network-address-translation-nat/13770-1.html
HTH.
RS.
Hello Rajeev
Thanks for the response. However, I want something that can nat from inside to outside first and then do make the routing decision.
Hey,
Well i dont think we have any option left then because as per NAT order of operations provided on the link below:
http://www.cisco.com/c/en/us/support/docs/ip/network-address-translation-nat/6209-5.html
NAT will follow after routing.
RS.
