04-28-2010 01:52 AM - edited 03-06-2019 10:50 AM
Is the 861W-GN series supports IP Multicast feature ?
In which IOS ?
05-03-2010 10:27 AM
No it does not support ipv6. You will need to upgrade to a 870 series with the Advanced IP Services software image.
You can pick another product, but the 870's are the 1st versions that have ipv6 support.
The 890 series is the 1st series that includes ipv6 support by default. The 890 includes the Advanced IP Features Set by default which is where the support comes from. So if you do pick a 890 make sure that you recieve the Advanced IP Features Set, which it should come with if you order it from an authorized dealer.
Here is the data sheet list for your review:
http://www.cisco.com/en/US/products/hw/routers/ps380/products_data_sheets_list.html
12-04-2010 04:08 PM
The question was about Multicast not ipv6!
12-04-2010 09:55 PM
860 series does not support multicast.. where in 880 series with Adv IP services feature set support Multicast
lemme know if this answered your question..
Surendra
Please dont forget to rate the post if this was helpful for you or usefull
12-05-2010 03:44 AM
Thank you very much.
