12-20-2006 02:10 PM - edited 03-05-2019 01:25 PM
I keep getting these messages under my syslog, it comes up for different ports, not all the time but enough to notice. This is on a 3750G stack of 8 switches.
12-20-2006 16:57:09 Local7.Notice 172.18.1.4 %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet7/0/9, changed state to up (Core-7)
12-20-2006 16:57:08 Local7.Notice 172.18.1.4 %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet7/0/9, changed state to up
12-20-2006 16:57:06 Local7.Notice 172.18.1.4 %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet7/0/9, changed state to down (Core-7)
12-20-2006 08:40 PM
do check out for the device connected on these ports..
what kinda devices are connected on these ports ?
regds
12-21-2006 08:58 AM
Laptops
12-23-2006 12:09 AM
If the laptop's are frequently coneected n disconnected on the network then its a normal behaviour.
Mahmood
12-23-2006 05:30 AM
as far as i can see this looks perfectly normal. all it means is that the device on port 9 of switch number 7, has been disconected. if it's a PC then it's probably been rebooted or the cable has been unpluged.
12-23-2006 06:49 AM
The logs would only be a concern if they are being generated without the Laptop being disconnected or restarted
If this is the case, check for errors on the switch interface and would probably be due to speed & duplex mismatch
Narayan
