12-28-2013 10:29 AM - edited 03-07-2019 05:17 PM
Hi Team,
We have Cisco ME-C6524GS-8S switch.We are facing issue with this switch.As we are suspecting issue with IOS.Can you please to resolve this?.I want to know "is the below IOS suitable for the below processor?".Because every day the device is restarted automatically.Hence we are facing issue with network.
e4b-ud-5a#show ver
Cisco IOS Software, s6523_rp Software (s6523_rp-ADVIPSERVICESK9-M), Experimental Version 12.2(20110209:202501) [hpimpalk-NMI_SXI4 100]
This software is supported for a limited time under special agreement with Cisco Systems, Inc. Reference case 616556157
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Wed 09-Feb-11 12:25 by hpimpalk
ROM: System Bootstrap, Version 12.2(17r)SX3, RELEASE SOFTWARE (fc1)
e4b-ud-5a uptime is 8 hours, 39 minutes
Uptime for this control processor is 8 hours, 41 minutes
Time since e4b-ud-5a switched to active is 8 hours, 38 minutes
System returned to ROM by power on at 04:16:03 GMT Wed Dec 18 2013 (SP by power-on)
System restarted at 09:03:14 GMT Sat Dec 28 2013
System image file is "sup-bootflash:s6523-advipservicesk9-mz-eng-special.122-33.SXI4.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
I
cisco ME-C6524GS-8S (R7000) processor (revision 1.1) with 458752K/65536K bytes of memory.
Processor board ID CAT103551VT
R7000 CPU at 300Mhz, Implementation 0x27, Rev 3.3, 256KB L2, 1024KB L3 Cache
Last reset from power-on
23 Virtual Ethernet interfaces
32 Gigabit Ethernet interfaces
1915K bytes of non-volatile configuration memory.
65536K bytes of Flash internal SIMM (Sector size 256K).
I am expecting your replies ASAP...
K.RANGARAJ
Network Engineer
12-29-2013 03:17 AM
Exactly where did you get the current IOS you are running?
Your IOS is classified as EXPERIMENTAL or "special engineering release".
I do not believe this specific IOS is designed for production. This specific IOS, in my opinion, is designed to get your appliance to work so users can upgrade to the appropriate IOS .
