is this sub interface or not
mahesh18
Level 6
Level 6
hi all,
i have router showing
sh ip int brief
Interface IP-Address OK? Method Status Prot ocol
GigabitEthernet0/0 141.197.104.254 YES NVRAM up up
GigabitEthernet0/1 10.39.1.57 YES NVRAM up up
ATM0/IMA0 unassigned YES NVRAM administratively down down
ATM0/IMA0.777 unassigned YES unset administratively down down
ATM0/IMA1 unassigned YES NVRAM up up
ATM0/IMA1.777 10.254.5.89 YES NVRAM up up
ATM0/0/0 unassigned YES NVRAM down down
ATM0/0/1 unassigned YES NVRAM down down
Serial0/1/0:0 10.39.1.29 YES NVRAM up up *********************** 1
Serial0/1/1:0 10.39.1.53 YES NVRAM up up ********************** 2
ATM0/2/0 unassigned YES NVRAM up up
ATM0/2/1 unassigned YES NVRAM up up
ATM0/3/0 unassigned YES NVRAM up up
ATM0/3/1 unassigned YES NVRAM up up
Serial1/0 10.39.1.21 YES NVRAM down down
Serial1/1 unassigned YES NVRAM administratively down down
Serial1/2 unassigned YES NVRAM administratively down down
Serial1/3 unassigned YES NVRAM administratively down down
Loopback0 10.39.15.1 YES NVRAM up up
Tunnel0 10.39.1.93 YES NVRAM up up
My question is if serial 1 and 2 are subinterfaces or hey are actual physical interfaces.
many thanks
Mahesh,
Your serial interfaces are what I explained above, and the T0/1/0 and T0/1/1 are the same serial card, but different ports on the same card.
John
HTH, John *** Please rate all useful posts ***
6 Replies 6
John Blakley
No, those are serial interfaces:
Serial 0/1/0:0
Serial 0/1/1:0
There is 1 serial card 0/1 and two ports 0:0 and 1:0.
The ":0" is the group that they belong to. If you look on the router, you'll probably see something like:
controller t1 0/0
channel-group 0 timeslots 1 - 24
controller t1 0/1
The "channel-group" number is appended to the card identifier to show you what group it's a member of.
HTH,
John
Hi hohn,
thanks for reply.
here i see router config
controller T1 0/0/0
mode atm aim 0
framing esf
linecode b8zs
controller T1 0/0/1
mode atm aim 0
framing esf
linecode b8zs
controller T1 0/1/0
framing esf
linecode b8zs
channel-group 0 timeslots 1-24
controller T1 0/1/1
framing esf
linecode b8zs
controller T1 0/2/0
mode atm aim 1
framing esf
linecode b8zs
controller T1 0/2/1
mode atm aim 1
framing esf
linecode b8zs
controller T1 0/3/0
mode atm aim 1
framing esf
linecode b8zs
so serail0/1 card which has 2 ports 0:0
and 0:1 belongs to which T1 controllers from above?
thanks
mahesh
I only see the one channel group. Do you see another somewhere?
John
Mahesh
In your original post are these lines:
and they belong to these T1 controllers:
controller T1 0/1/0
framing esf
linecode b8zs
controller T1 0/1/1
framing esf
linecode b8zs
Rick
Rick
Hi Rick,
thanks for reply
correct me if i am wrong
so this means we have one serial card se0/1 and it has 2 slots 0:0 and 1:0
and T1 0/1/0 is same as Serial0/1/0:0
thanks
mahehs
Mahesh,
John
