Webcast-Catalyst9k
Is WCCP Supported on WS-C3560G-24TS-E
I have been searching around, I know it is part of the 12.2 Firmware and beyond, but not finding any specific information in regards to this.
1 ACCEPTED SOLUTION
Hall of Fame Super Bronze
Re: Is WCCP Supported on WS-C3560G-24TS-E
Hall of Fame Super Silver
it is supported see the config chapter for 12.2(44)SE
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_44_se/configuration/guide/swwccp.html
you may need to check the following:
>>To use this feature, the switch must be running the IP services image (formerly known as the enhanced multilayer image [EMI]).
you need also to check the sdm you have
show sdm prefer
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_44_se/configuration/guide/swsdm.html#wp1140657
Hope to help
Giuseppe
195
