Is WS-X4248-RJ45V supported in 4507R?
I'm doing a customer build and when i insert the line card i get the following:
Switch#sh mod all
Mod Ports Card Type Model Serial No.
1 2 1000BaseX (GBIC) Supervisor(active) WS-X4515 J
2 2 1000BaseX (GBIC) Supervisor(standby) WS-X4515 J
5 0 Unsupported module WS-X4248-RJ45V J
M MAC addresses Hw Fw Sw Status
1 001b.2a90.e300 to 001b.2a90.e301 2.0 12.1(12r)EW 12.1(13)EW1, EAR Ok
2 001b.2a90.e302 to 001b.2a90.e303 5.0 12.2(20r)EW1 12.2(25)EWA5, Ok
5 001b.5341.1810 to 001b.5341.183f 3.3 Other
I thought that these linecards were supported on this Chassis number. Can anybody help or does anybody have a solution? (sorry to rush, but it's reasonably urgent)
Silver
Re: Is WS-X4248-RJ45V supported in 4507R?
hi!
Hardware wise , it seems to be supported. You will have to check if the ios version you are running supports it. Can you tell what IOS version are you running?
You can use the following link to findout the min supported release for your hardware config:
http://tools.cisco.com/Support/Fusion/FusionHCHome.do?mySession=6124872&myStep=2
Niranjan
(pls rate helpful posts)
I'm not sure which IOS i will need. Here's a copy of the output:
Switch#sh vers
IOS (tm) Catalyst 4000 L3 Switch Software (cat4000-IK2S-M), Version 12.1(13)EW1, EARLY DEPLOYMENT RE
LEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Tue 18-Mar-03 07:52 by hqluong
Image text-base: 0x00000000, data-base: 0x00F6AFAC
ROM: 12.1(12r)EW
Dagobah Revision 71, Swamp Revision 28
Switch uptime is 24 minutes
System image file is "bootflash:cat4000-ik2s-mz.121-13.EW1.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C4507R (XPC8245) processor (revision 7) with 524288K bytes of memory.
Processor board ID FOX110408VQ
Last reset from PowerUp
4 Gigabit Ethernet/IEEE 802.3 interface(s)
403K bytes of non-volatile configuration memory.
This line card requires a minimum of
"12.2(18)EW" IOS to be supported.
Mark
"And there we see the problem..."
Damn - OK, thanks for your help there Mark.
260
