isdn connection
hi all, i have established connection with a remote router via isdn, but i cannot ping any pc's past the router either end of the connection ? both networks are directly connected to each router. any ideas ?
Re: isdn connection
Hi Carl,
Do you have a route to reach the remote end network on both the routers?
Ankur
Silver
Re: isdn connection
Hi Carl,
Can you attach the sh run of routers.
Have you tried the extend ping from router to pc ? what is the stauts of sh isdn staus on both the routers ? Is isdn call is active ?
satish
Re: isdn connection
hi, the line is active and i can ping the remote router, the ip address of the router id on the same subnet as its lan, so it looks like the traffic hits the isdn dialler interface but doesnt get passed to the lan, i have a cisco router one end and a other branded one of the other end ? any ideas,
Re: isdn connection
Hi Carl,
Attach the run config for both the routers.
Ankur
114
