ISDN PRI
Can anybody please help me in configuring ISDN PRI E1 line.
I am using this link as backup for E1 leased line.
Thanks in Advance
Suresh
Re: ISDN PRI
Hi Suresh
You need to do the controller configs with necessary signaling used in your region and the bandwidth you are gonna allocate for each channel.
Once you are done with the config you need to do the serial interface config with necessary dialout config so that it can dial out in case your primary link goes down.
Do refer this link to get started..
http://www.cisco.com/en/US/products/sw/iosswrel/ps1831/products_configuration_guide_chapter09186a00800d9842.html#wp1001062
regds
Re: ISDN PRI
Prem thanks for the reply. In my case nobody is going to connect to this PRI line.
Actually what I want is, I have a 2Mbps leased line on Serial interface, now when it goes down I want ISDN link to comeup and send the data.
Hope you understood my requirment.
Thanks in Advance,
Suresh Jain
Re: ISDN PRI
Hi Suresh
You need to do 3 step configuration for your dial backup requirement using your PRI line.
Step 1 includes the following configuration :
isdn switch-type switch-type
framing crc4
linecode hdb3
pri-group
Step 2 includes configuring the serial interface based on your requirement (dialin or dial out) which is dial out in your case..
interface Serial0:23
no ip address
encapsulation ppp
dialer pool-member 10
isdn switch-type
no cdp enable
ppp authentication chap
ppp multilink
Step 3 includes dialer profiles which can be used to dial out..
interface Dialer1
ip address x.x.x.x y.y.y.y
encapsulation ppp
dialer remote-name remotename
dialer idle-timeout xxx(in sec)
dialer string xxxxxx
dialer load-threshold 1 outbound
dialer-group 1
ppp multilink
do take care of authentication with the SP side and also the dialer group.
Also for more info you can refer this link..
http://cisco.com/en/US/tech/tk801/tk133/technologies_configuration_example09186a0080094559.shtml
regds
Re: ISDN PRI
Sorry to bother you prem, still many doubts as I have never came accross with ISDN before.
What is the information that I need to collect from my ISDN provider.
What IP should I give it go dialer interface is it the same which I have given to me Serial interface or any other. Should I also give default route to dialer interface.
Thanks in Advance
Suresh Jain
Silver
Re: ISDN PRI
Hi Suresh ,
You need to collect following things from isdn provider.
1.ISDN number of local and remote sites.
2.check the framing , line code
3.who is providing ip address for isdn line
After getting the isdn numbers it is esy to configure the E1 as said above.
You need to configure the router for dialer as below.
ip route 0.0.0.0 0.0.0.0 dialer 0 120
The above route is called floating static route and it willn't present in routing table as long as serial line is up.
Hope it helps you.
satish
Re: ISDN PRI
Thanks for your help pre, I will configure it tomm. and let you know.
Suresh Jain
Re: ISDN PRI
Satish,
Is it possible for you to just explain me how the ISDN connectivity happens, I mean starting from router to end point.
Suresh Jain
315
