Community Member
ISIS Supported IOS
Hi;
If any one have any idea that what is ios supported isis on 2500 series of router, i have 2520 routers with the image c2500-is-l.123-22.bin but unable to run isis, it gives error protocol not in this image.
1 ACCEPTED SOLUTION
Re: ISIS Supported IOS
Your image doesnot support it. You need atleast c2500-p7-l.122-23a.bin to support IS-IS on your router. Please see the attached out from feature navigator for the supported IOS.
Please use the feature navigator tool in future for IOS selection for your routers.
www.cisco.com/go/fn
HTH,Please rate if it does.
-amit singh
www.cisco.com/go/fn
-amit singh
You would need Service Provider or Enterprise Plus feature set to run IS-IS. Here's one image that you can use, c2500-p-l.12.2-17c.
Sundar
244
