ISL and DOT1.Q
abbas.ali
Can catalsyt support mix and match? I wanna use some ports with ISL and and some with DOT1.Q trunking.  Is it possible or you are bound to use only one for the whole chassis.
6 Replies 6
Nagaraja Thanthry
You can use a mix of DOT1q or ISL trunks in the switch (except on some where ISL is not supported).
NT
Reza Sharifi
Hi Abbas,
In addition to NT's comments, here are some of the 6500 modules that do not support ISL:
When configuring Layer 2 LAN ports, follow these guidelines and restrictions:
The following switching modules do not support ISL encapsulation:
WS-X6502-10GE
WS-X6548-GE-TX, WS-X6548V-GE-TX, WS-X6548-GE-45AF
WS-X6148-GE-TX, WS-X6148V-GE-TX, WS-X6148-GE-45AF
http://scc.cisco.com/en/US/docs/routers/7600/ios/12.2SXF/configuration/guide/layer2.html
Reza
Addition to what was posted, the following model DO NOT support ISL:
2940/2950/2955, 2960/2960S
NOTE:
1900 will support ONLY ISL
to also add to this remember:
isl does not use a native vlan
if one side isl and the other is dot 1q the link will work you just will get native vlan miss matches on the dot1q side and also may course baby giant frames.
Scott
A switch can use a mixture of 802.1q and ISL encapsulations on trunk links but a trunk link between 2 switches must be the same encapsulation as ISL and 802.1q use very different methods when they add a vlan tag ie.
802.1q inserts a tag into the existing frame
ISL actually encapsulates the frame with a new header
so the 2 switches must agree on the encapsulation being used per trunk link otherwise they will be looking for the vlan information in the wrong place.
Jon
Leo Laohoo
Aside from what Jon's mentioned (+5), be aware that not all brand will support ISL.
