wuh
ISL trunk with a pc connecting on it.
I just read a post where one of you said if a pc connects to a switch port that is configured as ISL trunk, it should be isolated.
I just did a test about this. The PC can ping the gateway that is on the siwtch it connects to. The port is ISL trunk.
is this test result reasonalbe? or am i missing something here?
Thanks!
interface FastEthernet0/1
switchport trunk encapsulation isl
switchport trunk allowed vlan 1
switchport mode dynamic desirable
end
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: ISL trunk with a pc connecting on it.
Hello Han,
when I mentioned an ISL trunk I was meaning a port that is a trunk always not as a result of DTP negotiation
try the following
int fas0/1
switchport mode trunk
in this case the port is always a trunk and doesn't need to negotiate a trunk using DTP (another Cisco L2 protocol) like in your config. The PC doesn't asnwer to DTP messages and the port reverts to mode access
In your scenario if you use
sh int fas0/1 switchport
you should see
admin state : trunk or dynamic desirable
operational state: access port
your port should act as an access port in Vlan1 and as a result of this the PC is not isolated and can ping the default gateway on Vlan1.
Hope to help
Giuseppe
its because u have made the allowed vlan as 1 on the port which will be the default vlan.
As u r management IP configured under VLAN 1 SVI it should be able to ping it.
Mahmood
Hello Han,
try the following
int fas0/1
you should see
Hope to help
Giuseppe
wuh
Giuseppe:
thanks, that makes sense to me. I misunderstood your post.
Han
256
