ISL vs 802.1q
Hi, a couple of queries regarding trunking.
1. PVST+, CST, MSTP, RSTP are supported on 802.1q but not on ISL trunks. Is my understanding right?
2. Can Cisco as well as non-Cisco VoIP work over ISL trunk?
Re: ISL vs 802.1q
1. Most non-Cisco 802.1q switches maintain only a single instance of spanning tree, known as Mono Spanning Tree (MST), that defines the spanning-tree topology for all VLANs. When a Cisco switch is connected to a non-Cisco switch through an 802.1q trunk, the MST of the non-Cisco switch and the native VLAN spanning tree of the Cisco switch combine in order to form a single spanning tree topology, known as the Common Spanning Tree (CST).
2. ISL is Cisco's VLAN encapsulation method and supported only on Cisco's equipment through Fast and Gigabit Ethernet links.
Hope that helps.
Re: ISL vs 802.1q
Please note that the Multiple-instance Spanning Tree Protocol also uses the acronym MST or MSTP - be careful not to confuse these two.
Best regards,
Peter
Hall of Fame Super Blue
Re: ISL vs 802.1q
Dhananjay
1) PVST, RSTP and MST are supported over ISL trunks. Note that PVST+ isn't because PVST+ was a modification to PVST for use on 802.1q trunks.
Jon
Hall of Fame Super Silver
Re: ISL vs 802.1q
Hello Jon,
it may be a mistype
PVST+ supports ISL trunks I tested this on C6509 with CatOS 7.x
it supports also 802.1Q trunks.
It is the older PVST (that I never used) that cannot run over 802.1Q trunks.
Edit:
have you got experience of MST over ISL trunks?
Hope to help
Giuseppe
Re: ISL vs 802.1q
Hi Giuseppe
Thanks for letting me know. I suppose logically there is no reason why PVST+ should not run over ISL.
"have you got experience of MST over ISL trunks?"
Not directly but i remember a conversation that Francois was involved in a while back where he talked about running MST over ISL.
And it's not wise to doubt Francios on STP :-)
Jon
Re: ISL vs 802.1q
Guiseppe/Peter
I'm having a bit of a moment so you could either or both of you guys just sanity check what i have written in this thread -
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Network%20Infrastructure&topic=LAN%2C%20Switching%20and%20Routing&topicID=.ee71a04&fromOutline=&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cd4751f
I would appreciate you giving it the once over just to make sure i'm not talking nonsense !!
Many thanks
Jon
Re: ISL vs 802.1q
Hello Dhananjay,
1) PVST+ can run on ISL trunks actually original PVST supported only ISL trunks and PVST+ added support over 802.1Q trunks.
CST has only one instance, MST 802.1s and RSTP should work well only on 802.1Q trunks.
Rapid PVST should support ISL trunks being proprietary.
2)
A cisco ip-phone uses an implicit 802.1Q mini-trunk with
native-vlan = data vlan
voice-vlan = tagged vlan
because you cannot configure it directly but it relies on CDP for learning how to treat pc frames and voip frames ISL trunks are not supported.
Of course, being ISL proprietary you cannot ask a non cisco voip phone to support it.
Hope to help
Giuseppe
Hall of Fame Super Gold
Re: ISL vs 802.1q
The Catalyst c2950/c2960 series switches does NOT support ISL.
Re: ISL vs 802.1q
Thanks to all of you for the clarifications.
3027
