Webcast-Catalyst9k
ISR 1841 IOS issue
I get this error, I would like to know if should I get a IOS upgrade or can solve it changing something in the configuration.
*Oct 7 10:27:58.056: %SYS-2-CHUNKBADMAGIC: Bad magic number in chunk header, chunk 0 data 63FC3B58 chunkmag
ic 0 chunk_freemagic 6334E764
-Process= "<interrupt level>", ipl= 4, pid= 57
-Traceback= 0x60911268 0x6020FBF8 0x602D395C 0x619DE224 0x619DB188 0x619DB380
Router#
1 REPLY
Hall of Fame Super Gold
Re: ISR 1841 IOS issue
Javier
The error message about Bad magic number in chunk header is a sign of a problem in the version of IOS (and so is the traceback). I think that there is nothing that you can do in the config. The solution is an IOS upgrade.
I had a similar error message a while back. Upgrading the IOS to a more recent version fixed it just fine.
Rick
116
