ISSU on 4507R fails from 12.2(50)SG to 12.2(52)SG
e.hoehn
The problem is that after the standby SUP comes up again after the reload, it negotiates RPR instead of SSO course of:
%ISSU-3-PEER_IMAGE_INCOMPATIBLE: Peer image (cat4500-IPBASEK9-M), version (12.2(52)SG) on peer uid (2) is incompatible
%C4K_REDUNDANCY-6-MODE: ACTIVE supervisor initializing for rpr mode
I checked the feature navigator for the compatibility matrix but couldn't find any data neither for the 12.2(50)SG, nor for 12.2(52)SG.
Does anyone know if ISSU is compatible between these two versions ?
And: will the feature navigator be updated some day ?
Thanks in advance,
Emanuel
s.jankowski
Level 4
Level 4
I feel IOS it gets negotiated to RPR mode
Error Message %ISSU-3-PEER_IMAGE_INCOMPATIBLE: Peer image (%s), version (%s) on peer uid (%d) is incompatible
Explanation The peer client is incompatible.
Recommended Action Synchronize the configurations and reload the standby supervisor.
Error Message C4K_REDUNDANCY-6-MODE:[char] supervisor initializing for [char] mode
Explanation The supervisor that you are not directly connected to is currently initializing as either the active or standby supervisor, in RPR mode.
Recommended Action This is an informational message. No action is required.
