09-25-2013 03:00 AM - edited 03-07-2019 03:40 PM
Im configuring VSS on cisco switch 6500 .. Do i have to make same configuration on both switches ? Or standby switch will sync with the active one?
Sent from Cisco Technical Support Android App
Solved! Go to Solution.
09-25-2013 11:13 AM
Mirinda,
Once you configure the VSS there will be only one Active Plane.
Hence what ever you configure that would automatically present. You will not hae/get the option to configure on second switch. There will be only once active plan and what ever you configure that would be reflected to other automatically.
Inayath
*plz rate all usefull posts.
09-25-2013 03:46 AM
You need to configure both the devices after which both the switches will form the VSS:
Best documents :
Here is a white paper on VSS to help you get started:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps9336/white_paper_c11_429338.pdf
Also here is our 6500 VSS configuration guide:
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/vss.html
Configuration document for this -
https://supportforums.cisco.com/docs/DOC-29472
Simple way:
# host VSS
#switch virtual domain 100 >>> Domain id should be same on both the switch.
# Switch 1 --------------------------- Switch 2 at the other switch.
# int po1
# switch vitual link 1 >>>> Defining the Virtual link to Po1. (VSL link)
int t5/4
channel-group 1 mode on >>> Assining the portchannel.
#Switch convert mode virtual >>>> This will convert the standalone machine to VSS and it reboots automatically.
# reload >> This will reload both the VSS chasis
# redundancy reload shelf 1/2 >> To reload each chasis in vss 1/.2 defines the switch ids.
Inayath
*Plz rate if this info is helpfull.
09-25-2013 11:07 AM
Thanx for you quick reply.. But i didn't mean the VSS configuration itself , i mean switch configuration such as VLANs , OSPF
09-25-2013 11:13 AM
Mirinda,
Inayath
09-25-2013 11:55 AM
Drear inyathUlla
Got it ..Thank you for you help i appreciate
09-25-2013 11:57 AM
Mirinda,
Could you mark the thread as answered .
Inayath
