11-17-2010 07:55 AM - edited 03-06-2019 02:05 PM
I'm in trouble with my 1802 router. It's connected on ADSLoPOTS with PPPoA. I can ping any address on the Internet from my client, but I can't get, through a browser, the content of any sites (excluding google, orange (my ISP), and some other sites that require no multiple connection to fetch the page). Moreover, when I ping some particular address, I get one response then all the request fail. In fact, when I do a tracert of any domain, the route stop at the first step on a 172.16.x like address. The point is that there's no such network in my configuration.
Here's the configuration of my router:
Current configuration : 1899 bytes
! Last configuration change at 16:02:59 UTC Thu Nov 4 2010
version 15.0
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
ip dhcp excluded-address 192.168.10.210 192.168.10.254
ip dhcp pool dhcpvigeo
network 192.168.10.0 255.255.255.0
default-router 192.168.10.253
dns-server 192.168.50.250
domain-name vigeo.com
ip cef
license udi pid CISCO1801 sn FCZ142891VJ
interface ATM0
no ip address
ip virtual-reassembly
atm ilmi-keepalive
pvc 8/35
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface FastEthernet0
ip address 192.168.10.253 255.255.255.0
ip nat inside
duplex auto
speed auto
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface Vlan1
ip nat inside
interface Dialer0
mtu 1492
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp chap hostname fti/******
ppp chap password 0 ********
ppp pap sent-username fti/********* password 0 ******
no cdp enable
ip forward-protocol nd
no ip http server
ip nat pool dhcpvigeo 192.168.10.0 192.168.11.0 netmask 0.0.0.255
ip nat inside source list 1 interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
access-list 1 permit 192.168.10.0 0.0.0.255
dialer-list 1 protocol ip permit
control-plane
line con 0
line aux 0
line vty 0 4
login
end
I have another question: is it possible to fix dynamicly the bandwidth of Dialer0? because it's fixed at 56 Kb/s by default (I have a 8Mb/s connection).
Can someone help me to fix it ouf?
I have been working on that issue for 3 days.. So I have hardly googled, and didn't find anything relevant for my problem.
Thanks in advance,
Yannis Varni
Solved! Go to Solution.
11-17-2010 01:17 PM
hello
try the following config to see if you're having issues with MTU/fragmentation
ip adjust-mss 1452
more details here:
http://www.cisco.com/en/US/tech/tk175/tk15/technologies_tech_note09186a0080093bc7.shtml
hth
andy
11-17-2010 10:12 AM
Excuse me for the mistake, the tracert was launched on a VM wich was connected by NAT (it explains the result). But it doesn't solve my problem. Any suggestion?
Yannis Varni
11-17-2010 01:17 PM
hello
ip adjust-mss 1452
more details here:
hth
andy
11-18-2010 12:37 AM
Thanks for the command, it works fine now.
I have another question: is it possible to have a dynamic bandwidth for my ADSL connexion? because Dialer0 have a BD of 56kb/s and ATM0 876kb/s instead of 8Mb/s (which is my connexion capabiliy). Or is it a point of no importance?
Yannis Varni
11-18-2010 01:35 AM
the bandwidth settings on these interfaces are used for routing metrics etc and don't affe
ct the speed of your connection.
hth
andy
11-18-2010 02:19 AM
Thanks you very much for your support.
Have a nice day,
Yannis Varni
