Community Member
Issue with 3750 as Gateway
On a single LAN with two independent IP networks, will a 3750 switch used as the gateway keep traffic between networks off of the router? Can a single switch (or stack) be configured as gateway for both independent IP networks?
1 REPLY
Hall of Fame Super Bronze
Re: Issue with 3750 as Gateway
Yes to both questions.
The 3750 switch provides inter-vlan routing without the need for an external router.
You can configure the gateway on your end-hosts towards the Layer3 interface on the 3750 representing that Vlan.
HTH,
__
Edison.
116
