Issue with 4503E SUP
Hi All,
I have an issue with 4500 switch, we have supervisor engine 2 plus (WS-X4013+ )and it is working fine with switch 4506, but I have a requirement so need to use this old sup in a new chasis which is 4503-E. Whenever I use this sup with new 4503E it will never boot but it shows error "Unsupported chassis type 65535, system can not boot".
We have another new chasis(4503-E) which has got a new supervisor engine 2 plus (WS-X4013+) and it is working fine, this sup is same as which I used in 4506.
Anybody knows why the old sup is not working with new chasis and giving error, error text is attached.
Hall of Fame Super Blue
Re: Issue with 4503E SUP
Can you check the IOS version on your working 4503-E. According to the data sheet you need a minimum of 12.2(37)SG to run this supervisor in the 4503-E chassis.
In the chassis that is not working you have IOS version 12.2(25)EWA6 on the supervisor. So if the working 4503-E chassis has 12.2(37)SG or later on the Sup you may need to upgrade from 12.2(25)EWA6.
See attached data sheet, about halfway down for supported IOS versions
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps4324/product_data_sheet0900aecd801792b1.html
Jon
Hi Jon,
Now it is working fine, I upgraded IoS to12.2(37)SG.
Purple
As Jon says it has to be a IOS version issue we have tons of sup 2+'s in a 4506E chassis. Think we are running 12.2.37SG .
155
