01-10-2012 12:26 PM - edited 03-07-2019 04:16 AM
I have a Cisco 2821 running Version 12.4(3b)
We inserted the HWIC-4ESW and copied the config over from an identical router (same model, same card type, etc.). I'm not seeing the ethernet ports though! when i do a "show ip int br" all I can see is the two gig ports. I've tried reseating the card and reloading a few times. When I do a show inventory, I see the card listed. Help!
01-10-2012 01:24 PM
Do they show up when you issue "show int status " ? Wouldn't think it would need T train. these switchcards have been around since the 12.2T era so all the functionality should be in any later mainline versions.
01-10-2012 01:29 PM
Are you running the "T" train? If you are unsure, please post the output to the following command:
1. sh version; and
2. sh log
