Issue with x4648-rj45V+E module in 4507E
I have a problem with x4648-rj45V+E module, which is not forwarding frames/packets in my 4507E switch. I have done the diagnostic and the module test is passed. When i try to ping from one PC to another in the flat network, icmp is not forwarding. Even i cannot see the mac addresses in the mac address-table. But i can ping to my management port in the sup module? Am i missing something ? This is weird .
Please help me to solve this issue.
Purple
  Do you have all the firewalls turned off in your pc's that you are using to ping ?
Hall of Fame Super Gold
More info required.
1.  What IOS are you using?
2.  Is this affecting only one blade in the chassis?  Have you tried relocating the blade in another chassis?
3.  What's the configuration of the port in question?
4.  Stupid question from me:  Is the link up/up?  Can you post the output to the command "sh interface "?
Glen--> yes all my firewalls are disabled in the client PCs.
leolaohoo-->
Version 12.2(53)SG2, RELEASE SOFTWARE (fc1)
2.   Is this affecting only one blade in the chassis?  Have you tried  relocating the blade in another chassis? yes, i have tried relocating  the module to other slots, but still problem remains same.
3.  What's the configuration of the port in question? port has no configurations, just default config.
Best part is when i plug the cable, ports are showing up and up
Default config?  Please post it.  If it's in VLAN 1, is VLAN 1 allowed in your network?
Hi, this is a new switch and still we didn't connect to network. VLAN1 is showing up/up. check the outputs below.
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2012.03.28 10:58:46 =~=~=~=~=~=~=~=~=~=~=~=
ip int br
Interface              IP-Address      OK? Method Status                Protocol
Vlan1                  unassigned      YES NVRAM  up                    up
Vlan20                 xxx.xx.xx.x     YES manual administratively down down
Vlan21                 xxx.xx.xx.x     YES manual administratively down down
Vlan22                 xxx.xx.xx.x     YES manual administratively down down
Vlan23                 xxx.xx.xx.x     YES manual administratively down down
Vlan24                 xxx.xx.xx.x     YES manual administratively down down
Vlan25                 xxx.xx.xx.x     YES manual administratively down down
Vlan26                 xxx.xx.xx.x     YES manual administratively down down
Vlan27                 xxx.xx.xx.x     YES manual administratively down down
Vlan28                 xxx.xx.xx.x     YES manual administratively down down
Vlan29                 xxx.xx.xx.x    YES manual administratively down down
Vlan30                 xxx.xx.xx.x     YES manual administratively down down
Vlan31                 xxx.xx.xx.x     YES manual administratively down down
Vlan32                 xxx.xx.xx.x     YES manual administratively down down
Vlan33                 xxx.xx.xx.x     YES manual administratively down down
Vlan35                 xxx.xx.xx.x     YES manual administratively down down
Vlan36                 xxx.xx.xx.x     YES manual administratively down down
Vlan50                 xxx.xx.xx.x     YES manual administratively down down
Vlan99                 xxx.xx.xx.x     YES manual administratively down down
Vlan100                xxx.xx.xx.x    YES manual administratively down down
FastEthernet1          xxx.xx.xx.x     YES NVRAM  down                  down
TenGigabitEthernet1/1  unassigned      YES unset  down                  down
TenGigabitEthernet1/2  unassigned      YES unset  down                  down
TenGigabitEthernet1/3  unassigned      YES unset  down                  down
TenGigabitEthernet1/4  unassigned      YES unset  down                  down
TenGigabitEthernet1/5  unassigned      YES unset  down                  down
TenGigabitEthernet1/6  unassigned      YES unset  down                  down
GigabitEthernet1/7     unassigned      YES unset  down                  down
GigabitEthernet1/8     unassigned      YES unset  down                  down
GigabitEthernet1/9     unassigned      YES unset  down                  down
GigabitEthernet1/10    unassigned      YES unset  down                  down
GigabitEthernet1/11    unassigned      YES unset  down                  down
GigabitEthernet1/12    unassigned      YES unset  down                  down
GigabitEthernet1/13    unassigned      YES unset  down                  down
GigabitEthernet1/14    unassigned      YES unset  down                  down
GigabitEthernet1/15    unassigned      YES unset  down                  down
GigabitEthernet1/16    unassigned      YES unset  down                  down
GigabitEthernet1/17    unassigned      YES unset  down                  down
GigabitEthernet1/18    unassigned      YES unset  down                  down
TenGigabitEthernet2/1  unassigned      YES unset  down                  down
TenGigabitEthernet2/2  unassigned      YES unset  down                  down
TenGigabitEthernet2/3  unassigned      YES unset  down                  down
TenGigabitEthernet2/4  unassigned      YES unset  down                  down
TenGigabitEthernet2/5  unassigned      YES unset  down                  down
TenGigabitEthernet2/6  unassigned      YES unset  down                  down
GigabitEthernet2/7     unassigned      YES unset  down                  down
GigabitEthernet2/8     unassigned      YES unset  down                  down
GigabitEthernet2/9     unassigned      YES unset  down                  down
GigabitEthernet2/10    unassigned      YES unset  down                  down
GigabitEthernet2/11    unassigned      YES unset  down                  down
GigabitEthernet2/12    unassigned      YES unset  down                  down
GigabitEthernet2/13    unassigned      YES unset  down                  down
GigabitEthernet2/14    unassigned      YES unset  down                  down
GigabitEthernet2/15    unassigned      YES unset  down                  down
GigabitEthernet2/16    unassigned      YES unset  down                  down
GigabitEthernet2/17    unassigned      YES unset  down                  down
GigabitEthernet2/18    unassigned      YES unset  down                  down
TenGigabitEthernet3/1  unassigned      YES unset  down                  down
TenGigabitEthernet3/2  unassigned      YES unset  down                  down
GigabitEthernet3/3     unassigned      YES unset  down                  down
GigabitEthernet3/4     unassigned      YES unset  down                  down
GigabitEthernet3/5     unassigned      YES unset  down                  down
GigabitEthernet3/6     unassigned      YES unset  down                  down
TenGigabitEthernet4/1  unassigned      YES unset  down                  down
TenGigabitEthernet4/2  unassigned      YES unset  down                  down
GigabitEthernet4/3     unassigned      YES unset  down                  down
GigabitEthernet4/4     unassigned      YES unset  down                  down
GigabitEthernet4/5     unassigned      YES unset  down                  down
GigabitEthernet4/6     unassigned      YES unset  down                  down
GigabitEthernet5/1     unassigned      YES unset  down                  down
GigabitEthernet5/2     unassigned      YES unset  down                  down
GigabitEthernet5/3     unassigned      YES unset  down                  down
GigabitEthernet5/4     unassigned      YES unset  down                  down
GigabitEthernet5/5     unassigned      YES unset  down                  down
GigabitEthernet5/6     unassigned      YES unset  down                  down
GigabitEthernet5/7     unassigned      YES unset  down                  down
GigabitEthernet5/8     unassigned      YES unset  down                  down
GigabitEthernet5/9     unassigned      YES unset  down                  down
GigabitEthernet5/10    unassigned      YES unset  down                  down
GigabitEthernet5/11    unassigned      YES unset  down                  down
GigabitEthernet5/12    unassigned      YES unset  down                  down
GigabitEthernet5/13    unassigned      YES unset  down                  down
GigabitEthernet5/14    unassigned      YES unset  down                  down
GigabitEthernet5/15    unassigned      YES unset  down                  down
GigabitEthernet5/16    unassigned      YES unset  down                  down
GigabitEthernet5/17    unassigned      YES unset  down                  down
GigabitEthernet5/18    unassigned      YES unset  down                  down
GigabitEthernet5/19    unassigned      YES unset  down                  down
GigabitEthernet5/20    unassigned      YES unset  down                  down
GigabitEthernet5/21    unassigned      YES unset  down                  down
GigabitEthernet5/22    unassigned      YES unset  down                  down
GigabitEthernet5/23    unassigned      YES unset  down                  down
GigabitEthernet5/24    unassigned      YES unset  up                    up
GigabitEthernet5/25    unassigned      YES unset  down                  down
GigabitEthernet5/26    unassigned      YES unset  down                  down
GigabitEthernet5/27    unassigned      YES unset  down                  down
GigabitEthernet5/28    unassigned      YES unset  down                  down
GigabitEthernet5/29    unassigned      YES unset  down                  down
GigabitEthernet5/30    unassigned      YES unset  down                  down
GigabitEthernet5/31    unassigned      YES unset  down                  down
GigabitEthernet5/32    unassigned      YES unset  down                  down
GigabitEthernet5/33    unassigned      YES unset  down                  down
GigabitEthernet5/34    unassigned      YES unset  down                  down
GigabitEthernet5/35    unassigned      YES unset  down                  down
GigabitEthernet5/36    unassigned      YES unset  down                  down
GigabitEthernet5/37    unassigned      YES unset  down                  down
GigabitEthernet5/38    unassigned      YES unset  down                  down
GigabitEthernet5/39    unassigned      YES unset  down                  down
GigabitEthernet5/40    unassigned      YES unset  down                  down
GigabitEthernet5/41    unassigned      YES unset  down                  down
GigabitEthernet5/42    unassigned      YES unset  down                  down
GigabitEthernet5/43    unassigned      YES unset  down                  down
GigabitEthernet5/44    unassigned      YES unset  down                  down
GigabitEthernet5/45    unassigned      YES unset  down                  down
GigabitEthernet5/46    unassigned      YES unset  down                  down
GigabitEthernet5/47    unassigned      YES unset  down                  down
GigabitEthernet5/48    unassigned      YES unset  down                  down
WAEL_CORESW#
WAEL_CORESW#
WAEL_CORESW#
WAEL_CORESW#
WAEL_CORESW#show int
WAEL_CORESW#show interfaces gi
WAEL_CORESW#show interfaces gigabitEthernet 5/24 su
WAEL_CORESW#show interfaces gigabitEthernet 5/24 summary
*: interface is up
IHQ: pkts in input hold queue     IQD: pkts dropped from input queue
OHQ: pkts in output hold queue    OQD: pkts dropped from output queue
RXBS: rx rate (bits/sec)          RXPS: rx rate (pkts/sec)
TXBS: tx rate (bits/sec)          TXPS: tx rate (pkts/sec)
TRTL: throttle count
  Interface               IHQ   IQD  OHQ   OQD  RXBS RXPS  TXBS TXPS TRTL
* GigabitEthernet5/24      0     0    0     0  2000    3     0    0    0
WAEL_CORESW#
WAEL_CORESW#
WAEL_CORESW#
WAEL_CORESW#show run interface gi
WAEL_CORESW#show run interface gigabitEthernet 5/24
Building configuration...
Current configuration : 37 bytes
interface GigabitEthernet5/24
end
WAEL_CORESW#show vlan br
VLAN Name                             Status    Ports
1    default                          active    Te1/1, Te1/2, Te1/3, Te1/4
                                                Te1/5, Te1/6, Gi1/7, Gi1/8
                                                Gi1/9, Gi1/10, Gi1/11, Gi1/12
                                                Gi1/13, Gi1/14, Gi1/15, Gi1/16
                                                Gi1/17, Gi1/18, Te2/1, Te2/2
                                                Te2/3, Te2/4, Te2/5, Te2/6
                                                Gi2/7, Gi2/8, Gi2/9, Gi2/10
                                                Gi2/11, Gi2/12, Gi2/13, Gi2/14
                                                Gi2/15, Gi2/16, Gi2/17, Gi2/18
                                                Te3/1, Te3/2, Gi3/3, Gi3/4
                                                Gi3/5, Gi3/6, Te4/1, Te4/2
                                                Gi4/3, Gi4/4, Gi4/5, Gi4/6
                                                Gi5/1, Gi5/2, Gi5/3, Gi5/4
                                                Gi5/5, Gi5/6, Gi5/7, Gi5/8
                                                Gi5/9, Gi5/10, Gi5/11, Gi5/12
                                                Gi5/13, Gi5/14, Gi5/15, Gi5/16
                                                Gi5/17, Gi5/18, Gi5/19, Gi5/20
                                                Gi5/21, Gi5/22, Gi5/23, Gi5/24
                                                Gi5/25, Gi5/26, Gi5/27, Gi5/28
                                                Gi5/29, Gi5/30, Gi5/31, Gi5/32
                                                Gi5/33, Gi5/34, Gi5/35, Gi5/36
                                                Gi5/37, Gi5/38, Gi5/39, Gi5/40
                                                Gi5/41, Gi5/42, Gi5/43, Gi5/44
                                                Gi5/45, Gi5/46, Gi5/47, Gi5/48
1002 fddi-default                     act/unsup
1003 trcrf-default                    act/unsup
1004 fddinet-default                  act/unsup
1005 trbrf-default                    act/unsup
WAEL_CORESW#
WAEL_CORESW#WAEL_CORESW#show interfaces gigabitEthernet 5/24
GigabitEthernet5/24 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet Port, address is 7081.0528.04d7 (bia 7081.0528.04d7)
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, link type is auto, media type is 10/100/1000-TX
  input flow-control is on, output flow-control is on
  Auto-MDIX on (operational: on)
  Last input never, output never, output hang never
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 2000 bits/sec, 3 packets/sec
     6419 packets input, 563376 bytes, 0 no buffer
     Received 6419 broadcasts (1613 multicasts)
     0 packets output, 0 bytes, 0 underruns
     0 lost carrier, 0 no carrier
WAEL_CORESW#show
Do you have some ACL in place ?
I can see only one interface as up, which one is the trunk here ?
Come up with complete scenario .... IP Addresses, MAC Addresses, Mac Table in the switch etc.
I am sure .. we will get a way from here !!
Parvesh
Hi Parvesh,
This is actually not connected to the network or any other switches. Just now am started to install the switch. By using  vlan 1 we should be able to ping from one pc to another . This is the default functionality of the switch, if am not not wrong!
But when i connect two PCs to this module and ping them in between, am not getting any reply.
I used one PC as 192.168.1.1/24 and another with 192.168.1.2/24.
I'm not seeing any MAC address in the mac address table, regarding those two pcs.
I did configured the management port in the primary sup module and try to ping from the client, am getting the reply back.
Hope, now u got the scenarion what am talking about!!!
Please post the output to the command "sh run int GigabitEthernet5/24".
end
Try putting "spanning portf".
Can you please confirm if the same hosts are responding to each other .. through a cross cable...
Any logs .. ?? Try to debug IP packets  and share the result here ... !!
Parvesh
Hi Guys,
I have another 2 new 3750s where i can able to ping between two same PCs. And the 3750 is learning the mac address from the PCs.
But 4507 ethernet module is not even learning from the PC. I checked with packet sniffer and i can see the "arp request" is forwarded to the switch module. but i don't see any "arp reply" from the switch module. I think some hardware issue. Going to open a case with cisco and confirm the issue. Then i hope i can get a replacement module via RMA process.
Thank you for your responces.
kajen
606
