It is possible to have load balancing between 2 servers on a single switch?
Tiago Reis
My question is: I will have packets that come from sw1 to a server, its possible to make load balancing on the switch in order to he decided if the packet goes to server 1 or server 2?
I cannot see how can be possible if the servers will have differents ip address.
Can anyone explain please?
Thanks in advance,
Tiago
2 Accepted Solutions
Collin Clark
You have two options; Server Load Balancing (SLB) on the higher end switches or the Application Control Engine (ACE).
Hope it helps.
Jason Masker
Here is the configuration guide for server load balancing, if your switch supports it.
http://www.cisco.com/en/US/customer/docs/ios/12_2/ip/configuration/guide/1cfsflb.html
If you do not have a CCO, use this link:
http://www.cisco.com/en/US/docs/ios/12_2/ip/configuration/guide/1cfsflb.pdf
Collin Clark
Hope it helps.
Jason Masker
Wooohhh that was very fast .)
Thats something new for me. (always learning...)
Thanks for your help (both of you).
Best Regards,
Tiago
