jumbo frame question
julxu
hi
if I want enalbe jumbo frame support on cisco 6500 ios ver 12.2(33) SXI2a, what impact will occur?
and can I enable jumbo frame support only on a subnet/vlan?  specially, can I enable jumbo frame only on certain ports?
Any comments will be apprecaited
Thanks in advance
julxu
8 Replies 8
francisco_1
Level 7
Level 7
that will depends on what cards you have installed.
post "show module"
Francisco
thanks for the reply.
I have ws-x6748-ge-tx, also ws-x6704-10ge. on cat6500 (vss).  but, I will put jumbo frame on ws-x6748-ge-tx card.
so, if I want just configure it on port only, what I need do is only configre the MTU to 9128, right?
question, since another end is a workstation, which on a cat3750 connected to other cat6500, if I enbale jumbo frame on port also on cat3750
can both talk to each other?  do I need do anything else?
Lei Tian
The ability of supporting jumbo frame size is vary on each module. If your module support it, then yes you can configure jumbo frame for certain ports.
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/intrface.html#wp1041111
HTH,
Lei Tian
Lei Tain
thank for the url,
I have more than one machine need this jumbo frame, and they are on differenct cat6500, some of them even on layer 2 switch cat3750s.
can I just set MTU to 9126 only, can the server use jumbo frame to the client with located on other cat6500 and other cat3750s?
if not, could you please advice me what configuration I need to make them working together?
Thanks in advance
julxu
Hi julxu,
You can also enable jumbo frame on your 3750s.  With 6500 you can do a globally or one module at the time, but with 3750s you can only enable it globally.  Also the 3750s require a reboot in order for the jumbo frame size to take effect, so be sure to do it during on outage.
Reza
Hi julxu,
What's your 3750's model? 3750 supports 9018 bytes jumbo frame on GE port, 3750-E supports 9216 bytes on GE port. You need to make sure all the ports along the path support the jumbo frame size, otherwise packet will be fragment and forward by software.If you want the server-client traffic benefit from jumbo frame, then I think you both NIC need to support jumbo frame as well.
HTH,
Lei Tian
hi everyone
thanks for all the emails.
last qeustion, since it involves large packets everywhere, will I have furture perfermance problem? thoughtout problems? or other problems which will interrupt our services? specially video/voice facility which all linked to same cat6500s/cat3750s?
if so, do I have some work around to fix it?
Many Regads
julxu
Hi julxu,
If there is fragmentation caused by MTU mismatch, then it might impact switch performance and affect other services. Otherwise, it is fine.
HTH,
Lei Tian
