Webcast-Catalyst9k
Jumbo Frames and connecting non-jumbo Switches
All,
I wander if you can help with this.
I currently have 4 3560 switches connected in a Mesh topology. These are all set to use Jumbo Frames and so are all the Servers that are connected to these.
I now need to connect a 2950 switch to 2 of the 3560's which will have only desktop computers connected to it but i do not want to configure Jumbo Frames on this and any of the desktops.
Can this be done with out causing any problems?
Thanks for you help
James
Everyone's tags (3)
1 ACCEPTED SOLUTION
Hi James,
Yup if opposite port is not able to send jumbo frames, there is no need to enable jumbo frames on 2950...
HTH,
Smitesh
PS: Please rate helpful posts...
Hi James,
Can you tell us why you require Jumbo frames ??
Well, as far as compatibility is concerns, unless you are not running Q-in-Q, there won't be any major issue; apart from if any frame comes which is larger than default MTU of 2950 will be discarded.
HTH,
Smitesh
Thanks for the quick response.
I didn't really want to go into the switch setup as it is actually 10 switches with a few VLANs.
One of these VLANs is a Storage VLAN and is the reason I want to use Jumbo Frames, so that i can get the most out of my iSCSI SANS.
To do so, I have had to enable Jumbo Frames and as these switches only allow jumbo frames on or off (as aposed to per port or vlan) then i need to enable this on all 1000Mbps devices.
I have just realised that I have not enable Jumbo on the switches for anything that is connected at 10/100Mbps and the 2950 switches are only capable of 10/100Mbps.
As this is the case, does this mean that I do not have to change anything for these switches to connect and operate without causing any discards or problems?
James
Hi James,
HTH,
Smitesh
436
