Webcast-Catalyst9k
Jumbo Frames on 4500 and 6500
per enclosed Visio I am setting up a back-up solution.
Server LAN to Commvault is a standard 1500 mtu network.
I need to set-up the connection from CommVault to NexSAN devices (storage) using Jumbo frames (9198) end-to-end
My core switch wont permit a MTU per-interface change option only a system option and, the 4500s will permit a per-interface change up to
1552 only.i.e.
CORE6500(config-if)#mtu ?
% Unrecognized command
CORE6500(config)#system ?
  jumbomtu  Configure system jumbo mtu size
DIST4500(config-if)#mtu ?
  <1500-9198>  MTU size in bytes
(config)#system mtu ?
  <1500-1552>  MTU size in bytes
I want to create a single VLAN connecting the CommVault to the NexSAN devices across the 3 switches with an MTU of 9198.
I don't want to affect the MTU of any other ports/VLANS as the core LAN shares these switches.
Can you help?
342
