L3 - L2 connection
Latchum Naidu
Hi All,
I have one L3 switch 3560 and 2 L2 2950 switches connected to it.
1. Trunk enabled on both sides (L3->L2 & L2->L3)
2. Configured Vlan1 on L2 switches (IP: 10.28.1.2)
3. Default gateway on L2 switches is 10.28.1.1 (one of the Vlan IP in L3 switch)
4. Checked Vlan status in L3 is active and connected one PC directly to L3 switch and its able to ping the GW (10.28.1.1)
But I am not able to ping from L2 switches to the default gateway which is one of the Vlan IP in L3 switch.
Is there anything need to check in the configuration or something?
Thanks & Regards,
Naidu.
11 Replies 11
Jon Marshall
naiduccnp wrote:
Hi All,
Thanks & Regards,
Naidu.
Naidu
Is 10.28.1.1 assigned to vlan 1 on the L3 switch ?
Can you post the following output from all 3 switches
sh ip int brief
sh int trunk
sh ip route
Jon
Hi Jon,
Thanks for your quick response.
10.28.1.1 is assigned to Vlan 101 on L3 switch.
sh int trunk & sh ip route not working on L2 switches.
L3 switch output:
Coreswitch - 10.26.6.1#sh ip int bri
Interface              IP-Address      OK? Method Status                Protocol
FastEthernet0/1        unassigned      YES manual up                    up
FastEthernet0/2        unassigned      YES manual up                    up
FastEthernet0/3        unassigned      YES manual up                    up
FastEthernet0/4        unassigned      YES manual up                    up
FastEthernet0/5        unassigned      YES manual up                    up
FastEthernet0/6        unassigned      YES manual down                  down
FastEthernet0/7        unassigned      YES manual down                  down
FastEthernet0/8        unassigned      YES manual down                  down
FastEthernet0/9        unassigned      YES manual down                  down
FastEthernet0/10       unassigned      YES manual down                  down
FastEthernet0/11       unassigned      YES manual down                  down
FastEthernet0/12       unassigned      YES manual down                  down
FastEthernet0/13       unassigned      YES manual down                  down
FastEthernet0/14       unassigned      YES manual down                  down
FastEthernet0/15       unassigned      YES manual down                  down
FastEthernet0/16       unassigned      YES manual down                  down
FastEthernet0/17       unassigned      YES manual down                  down
FastEthernet0/18       unassigned      YES manual down                  down
FastEthernet0/19       unassigned      YES manual down                  down
FastEthernet0/20       unassigned      YES manual down                  down
FastEthernet0/21       unassigned      YES manual down                  down
FastEthernet0/22       unassigned      YES manual down                  down
FastEthernet0/23       unassigned      YES manual down                  down
FastEthernet0/24       unassigned      YES manual down                  down
GigabitEthernet0/1     unassigned      YES manual up                    up
GigabitEthernet0/2     unassigned      YES manual up                    up
Vlan1                  unassigned      YES manual up                    up
Vlan100                10.26.6.1      YES manual up                    up
Vlan101                10.28.1.1       YES manual up                    up
Vlan999                192.16.19.1   YES manual up                    up
Coreswitch - 10.26.6.1#sh int tru
Coreswitch - 10.26.6.1#sh int trunk
Port        Mode         Encapsulation  Status        Native vlan
Fa0/1       on           802.1q         trunking      1
Fa0/2       on           802.1q         trunking      1
Port        Vlans allowed on trunk
Fa0/1       1-1005
Fa0/2       1-1005
Port        Vlans allowed and active in management domain
Fa0/1       1,99,100,101,999
Fa0/2       1,99,100,101,999
Port        Vlans in spanning tree forwarding state and not pruned
Coreswitch - 10.26.6.1#sh ip route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
       i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
       * - candidate default, U - per-user static route, o - ODR
       P - periodic downloaded static route
Gateway of last resort is not set
     10.0.0.0/24 is subnetted, 2 subnets
C       10.28.1.0 is directly connected, Vlan101
C       10.26.6.0 is directly connected, Vlan100
C    192.16.19.0/24 is directly connected, Vlan999
1 L2 Switch Output:
Switch-02#sh ip int bri
FastEthernet0/3        unassigned      YES manual down                  down
FastEthernet0/4        unassigned      YES manual down                  down
FastEthernet0/5        unassigned      YES manual down                  down
Vlan1                  10.28.1.3       YES manual up                    up
2 L2 Switch Output:
Switch - 10.28.1.2#sh ip int bri
Vlan1                  10.28.1.2       YES manual up                    up
Thanks & Regards,
Naidu.
Naidu
Your problem is that you have used vlan 1 on the switches but vlan 101 on the L3 switch. You can't do this. You either need to
1) on the L3 switch bring up vlan 1 interface and give it the address that is assigned to vlan 101
OR
2) a better solution is to shutdown vlan 1 interface on each L2 switch. Create a vlan 101 L3 interface and give it the IP address you have currently assigned to vlan 1 eg.
2950(config)# int vlan 1
2950(config-if)# no ip address
2950(config-if)# shut
2950(config)# int vlan 101
2950(config-if)# ip address 10.28.1.2 255.255.255.0
2950(config-if)# no shut
Jon
Hi Jon,
What I through really is the Vlan1 on L2 switches as a Management IP for them.
And one of the Vlan IP on L3 switch used as a DG for L2 switches
Is that wrong?
As you guided, I shutdowned the Vlan1 in L2 switches and creaed one Vlan101 (10.28.1.2) Still I am unable to ping from L2 switches to their DG.
DG is one of the Vlan IP on L3 switch.
Please find the below confing of one of the L2 switch:
Switch - 10.28.1.2#sh run
Building configuration...
Current configuration : 1183 bytes
version 12.1
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname "Switch - 10.28.1.2"
ip name-server 0.0.0.0
interface FastEthernet0/1
description connected to Coreswitch-01
switchport mode trunk
interface FastEthernet0/2
switchport access vlan 101
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface Vlan1
shutdown
interface Vlan101
ip default-gateway 10.28.1.1
line con 0
line vty 0 4
login
line vty 5 15
login
end
Thanks & Regards,
Naidu.
Naidu
Is that wrong?
Yes, it is wrong. The switches send their traffic in vlan 1 but on the L3 switch you have used vlan 101 for the same subnet so this traffic will never get through. If you are using subnet 10.28.1.0/24 then all switches must agree on the vlan used for it.
On your 2950 switch
int vlan 1
no ip address
then can you post
"sh ip interface brief"
"sh interface trunk"
"sh vlan"
from that 2950.
Jon
Hi Jon,
I removed the IP address for Vlan 1
Please find the below required details and config of one of the switch.
Switch-02#sh run
Current configuration : 1103 bytes
version 12.1
hostname Switch-02
duplex full
interface Vlan1
no ip address
interface Vlan101
line con 0
line vty 0 4
login
line vty 5 15
login
end
Vlan101                10.28.1.2       YES manual up                    up
Switch-02#sh interfaces trunk
Fa0/1       1-1005
Fa0/1       1,101
Fa0/1       1
Switch-02#sh vlan
VLAN Name                             Status    Ports
1    default                          active    Fa0/3, Fa0/4, Fa0/5, Fa0/6
                                                Fa0/7, Fa0/8, Fa0/9, Fa0/10
                                                Fa0/11, Fa0/12, Fa0/13, Fa0/14
                                                Fa0/15, Fa0/16, Fa0/17, Fa0/18
                                                Fa0/19, Fa0/20, Fa0/21, Fa0/22
                                                Fa0/23, Fa0/24
101  VLAN0101                         active    Fa0/2
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
VLAN Type  SAID       MTU   Parent RingNo BridgeNo Stp  BrdgMode Trans1 Trans2
1    enet  100001     1500  -      -      -        -    -        0      0
101  enet  100101     1500  -      -      -        -    -        0      0
1002 fddi  101002     1500  -      -      -        -    -        0      0
1003 tr    101003     1500  -      -      -        -    -        0      0
1004 fdnet 101004     1500  -      -      -        ieee -        0      0
1005 trnet 101005     1500  -      -      -        ibm  -        0      0
Remote SPAN VLANs
Primary Secondary Type              Ports
Thanks & Regards,
Naidu.
Naidu
Can you still not ping the gateway 10.28.1.1 ?
Jon
From your output
Fa0/1       1-1005
Fa0/1       1,101
Fa0/1       1
Did you create vlan 101 on the L3 switch? Is it allowed on the other side?
I've first to review your config. Maybe it's in there
Can you post a show run int fasx/x of the connected interface at the l3 switch?
davy.timmermans wrote:
From your output
Fa0/1       1-1005
Fa0/1       1,101
Fa0/1       1
Davy
Good spot, i missed that
Jon
Hi Jon,
Yes I have created vlan 101 in L3 switch and in L2 switch.
Please find the below running config of L2 switch:
Switch-02#sh run
Current configuration : 1120 bytes
version 12.1
hostname Switch-02
description Connected to L3
duplex full
interface Vlan1
no ip address
interface Vlan101
line con 0
line vty 0 4
login
line vty 5 15
login
end
Please find the below vlan info in L3 switch and the interface config which was connected to L2 switch:
description Connected to Switch-02
duplex full
Coreswitch - 10.16.6.1#sh vlan brief
1    default                          active    Fa0/6, Fa0/7, Fa0/8, Fa0/9
                                                Fa0/10, Fa0/11, Fa0/12, Fa0/13
                                                Fa0/14, Fa0/15, Fa0/16, Fa0/17
                                                Fa0/18, Fa0/19, Fa0/20, Fa0/21
                                                Fa0/22, Fa0/23, Fa0/24
99   VLAN0099                         active
100  VLAN0100                         active    Fa0/4
101  VLAN0101                         active    Fa0/3
999  VLAN0999                         active    Fa0/5, Gig0/1, Gig0/2
1002 fddi-default                     active
1003 token-ring-default               active
1004 fddinet-default                  active
1005 trnet-default                    active
Naidu.
Hi Jon,
Any findings on my previous post. I am eagerly waiting for the solution.
Naidu.
