L3 Switch Gig Interface Message.
hello all,
One of our cisco 4500 series L3 switch is not accepting "no switchport" comand on its Gig port. As of now the port is L2.
Giving below message after executing command "no switchport" on gig interface:-
Cisco_4507_Switch#no switchport
Command rejected: Not a convertible port.
IoS version on the switch is :-
System image file is "bootflash:cat4000-i9k91s-mz.122-20.EWA4.bin"
cisco WS-C4507R (MPC8245) processor (revision 4) with 524288K bytes of memory
What could be the reason for the message ...how to overcome the problem..
Bronze
Re: L3 Switch Gig Interface Message.
Hi Jimmy.
What kind of Supervisor do you have?
Also, the snip you show looks like you're not in conf t mode - is that right?
Silver
are you under interface mode?
from your prompt you are under the exec mode.
you must enter one interface then issue the command
switch#config t
switch(config)# interface gig 1/15
switch(config-if)#no switchport
Hello freinds,
that was typo, Please find the correct configs.
Cisco_4507_Switch(config)#int gi4/4
Cisco_4507_Switch(config-if)#no switchport
Cisco_4507_Switch#
Supervisor :-
Mod Ports Card Type Model
1 2 1000BaseX (GBIC) Supervisor(standby) WS-X4516
2 2 1000BaseX (GBIC) Supervisor(active) WS-X4516
Hall of Fame Super Gold
Depends if your supervisor card can do L3.
170
