L3 Switching Engine WS-F6K-PFC
I have Sup IA, its boots up and comes to console>(enable) mode, i need to configure L3 functionalities, not able to go with session 15, pls let me know how to configure the same.
Pls look into the below configuration.
sh module
Mod Slot Ports Module-Type Model Sub Status
1 1 2 1000BaseX Supervisor WS-X6K-SUP1A-2GE yes ok
2 2 2 1000BaseX Supervisor WS-X6K-SUP1A-2GE yes standby
3 3 48 10/100BaseTX Ethernet WS-X6248-RJ-45 no ok
4 4 48 10/100BaseTX Ethernet WS-X6348-RJ-45 yes ok
5 5 48 10/100BaseTX Ethernet WS-X6248-RJ-45 no ok
6 6 48 10/100BaseTX Ethernet WS-X6248-RJ-45 no ok
7 7 48 10/100BaseTX Ethernet WS-X6348-RJ-45 yes ok
8 8 48 10/100BaseTX Ethernet WS-X6348-RJ-45 yes ok
9 9 48 10/100BaseTX Ethernet WS-X6348-RJ-45 yes ok
Mod Module-Name Serial-Num
1 SAD042303TF
2 SAD042303HZ
3 SAD041905TV
4 SAL08239KDK
5 SAD041905LJ
6 SAD041905PW
7 SAL062517N2
8 SAL062720C0
9 SAL063242GR
--More--
Mod MAC-Address(es) Hw Fw Sw
1 00-b0-8e-83-7e-a6 to 00-b0-8e-83-7e-a7 3.1 5.3(1) 7.6(3a)
00-b0-8e-83-7e-a4 to 00-b0-8e-83-7e-a5
00-0b-45-95-cc-00 to 00-0b-45-95-cf-ff
2 00-b0-c2-f5-a7-82 to 00-b0-c2-f5-a7-83 3.1 5.3(1) 7.6(3a)
00-b0-c2-f5-a7-80 to 00-b0-c2-f5-a7-81
3 00-01-97-15-b6-80 to 00-01-97-15-b6-af 1.2 5.1(1)CSX 7.6(3a)
4 00-11-21-b1-c3-e0 to 00-11-21-b1-c4-0f 8.1 5.4(2) 7.6(3a)
5 00-01-97-15-f6-a0 to 00-01-97-15-f6-cf 1.2 5.1(1)CSX 7.6(3a)
6 00-01-97-0e-38-d0 to 00-01-97-0e-38-ff 1.2 5.1(1)CSX 7.6(3a)
7 00-09-b7-93-98-54 to 00-09-b7-93-98-83 6.1 5.4(2) 7.6(3a)
8 00-09-b7-93-b5-d0 to 00-09-b7-93-b5-ff 6.1 5.4(2) 7.6(3a)
9 00-09-b7-93-b6-00 to 00-09-b7-93-b6-2f 6.1 5.4(2) 7.6(3a)
Mod Sub-Type Sub-Model Sub-Serial Sub-Hw Sub-Sw
1 L3 Switching Engine WS-F6K-PFC SAD04230AJN 1.1
2 L3 Switching Engine WS-F6K-PFC SAD04230ABJ 1.1
4 Inline Power Module WS-F6K-VPWR 2.0 1.0
7 Inline Power Module WS-F6K-VPWR 1.0 1.0
8 Inline Power Module WS-F6K-VPWR 1.0 1.0
--More-- 9 Inline Power Module WS-F6K-VPWR 1.0 1.0
Re: L3 Switching Engine WS-F6K-PFC
There aren't any MSFC's daughter card install in your switch:
#module 15 empty
#module 16 empty
MSFC's will show up in your "show module" command as module 15 or 16, depend on which line card.
HTH,
jerry
jerry,
you are right, but there is PFC card, in sh module status, you can see L3 Switching Engine, where we have a similar switch being used for L3. also this switch was earlier used as distribution switch, still working on it.
will share if done.
regards
Sara
Hi Sara,
SUP1A can come with the PFC but without the MSFC (like the one you have). In this case, the SUP will use the PFC to process frames for L3/4 QoS classification and ACL filtering.
Please see the following page from Cisco Press for the detail explaination:
http://www.ciscopress.com/articles/article.asp?p=102093&seqNum=2
HTH,
jerry
613
